I recently inspected a home that is 99 years old, had a concrete retaining wall poured, around the foundation, according to the buyer an engineer was hired, to help with this job, 1 steel L beams were installed vertically, (this was new to me as I have not seen L beams vertical, usually I beams horizontally), Im not an engineer.
my question is, what would you comment on the pictures I have included. There are near the back door, above grade, infront of the window you can see the retaining wall, that has been poured. The area near the back door the concrete is crumbling, Thanks for your sharing. Last edited by enorthe; 10/4/11 at 4:30 AM.. |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Perhaps posting the pic's to be commented on would help.
sorry, found the answer. thanks
did not know how to erase. |
How about sharing anyway, for the sake of education. Who knows when someone will run across the same issue? Thanks in advance.
| 2nd Floor Concrete Issues | DkDismayed | AskNACHI.org Inspection Questions Forum | 5 | 1/13/10 11:16 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
