Old 6/7/11, 1:02 AM
ksherman ksherman is offline
Default Crystalline Substance on gravel in crawl space
Need some advice. Never seen this before. Inspected a crawlspace today. The dirt floor had been covered with a heavy 6mil plastic and then 2-3 inches of pea gravel was added.
The gravel over a considerable area of this floor was damp and had a crystal like substance on it. Looked like salt crystals. Any idea what this might be?
In addition, digging down through the gravel, the plastic itself was wet. Found no efflorescence on the concrete walls. The drainage around the house was positive. Any thoughts on why the gravel and topside of the plastic is wet?
Thanks for your help
Ken Sherman
Sherman Home Inspection Services, LLC
Lake Villa, IL
(224) 637-0960
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/7/11, 4:49 AM
Brian E. Kelly's Avatar
Default Re: Crystalline Substance on gravel in crawl space
Probably Salt Crystals
Old 6/7/11, 9:01 AM
Banned
Not good!
Water getting onto plastic from
(1) condensation on floor framing then dripping down
(2) plumbing leakage (found a laundry drain never connected in a crawlspace of a realtor's house in an upscale town near here.
(3) leakage from the exterior
(4) uneven ground with dips in grade in combination with a high water table in certain conditions
Old 6/7/11, 9:09 AM
Roy D. Cooke, Sr's Avatar
More info would help is it vented to the out side if so this could be the cause Cool floor warm moist air condences on colder floor .
A dehumidifer set at 50% drained to a sump could help .
Read this send me your phone and I will call ... Roy
http://www.hgtvpro.com/hpro/bp_found...463221,00.html
Old 6/7/11, 1:59 PM
Christopher Currins's Avatar
photos??
Christopher Currins
Certified, Licensed
Old 6/8/11, 11:00 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Is there a water softener and does it discharge into the crawlspace?
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 6/9/11, 12:47 AM
Here are a couple of pictures. Upon closer look, I noted a lot of moisture in the gravel around the sewer waste lateral connection in the crawlspace. The PVC connection to the cast iron appeared to be tight and I could not find any evidence of leaking or condensation along the PVC. There is also some "mold like" substance visible on the foundation wall by the pipe. Also found similar patches of "mold-like" material in other corners of the crawl and unfinished basement. The camera also picked up what appears to be some efflorescence on the galvanized ducts. There is definitely excessive moisture in the crawl space.
Possible contributors may be significant vegetation growing right next to the house on all corners of the crawl space. All downspouts discharge above grade on to short (12-14 inch) concrete splash guards, so water is not being properly diverted away from the house.
This area is not vented, but it does directly connect to the basement. The opening between the basement and the crawl has been finished with two doors (hatches) providing access to the crawl area. The majority of the wet gravel is on the right half of the crawl as viewed in the photo.
Thanks for any and all input.
Ken Sherman
Lake Villa, IL
(224) 637-0960
Old 7/9/11, 10:41 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
I was going to say effervescence on the material the arrogate is made of.
Did you do a moisture reading of the earth or arrogate?
Sample of the joists.
The joists look like ceder. Is the home near salt water?
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Incorrect crawl space advice from BC rcooke Canadian Inspectors 50 1/26/11 4:38 PM
Anyone write up the lack of gravel in a new construction crawl space? jfunderburk Structural Inspections 14 8/19/10 11:48 PM
Crawlspace ventilation help pmassie Canadian Inspectors 47 3/2/10 9:54 AM
Pea gravel in a crawl space Rick Vollmer Structural Inspections 8 4/20/09 1:01 PM
