I thought this was an act of stupidity.
I reported as improperly cut. Dave Last edited by dmacy; 11/25/08 at 6:30 PM.. |
ccoombs is a non-member guest and is in no way affiliated with InterNACHI or its members.
I disagree with the statement the beam is "improperly cut." If the cut was made per an engineer's specification and/or detailing it may be fine. I agree it should be noted in the inspection report, but to state it is "improperly cut" isn't accurate, in my opinion.
Ingenious. If you can't work around the i-beam cut through it.
One of the anagrams for ingenious is I no genius.
I agree with Curtis, improperly cut is the wrong term. It's a bit close to the flange for my comfort level - the upper flange is in compression - but depending on its design strength, it may be okay.
I may have walked right past this, but if I felt it was questionable, I would have simply deferred it for review or evaluation. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
As stupid as this co-ordination effort looks like, the burnt cut out in this beam did not weaken it that much as one would expect.
Although not a common practice to burn holes in beams to provide a door opener, I would not note that it was improperly done unless it was on record that it was not recommended by the structural Engineer to do so. In most cases, you will find the the door installer took it upon himself with the owners agreement to cut the whole. Report what you see with no comment as to whether it is correct or not. Don't guess, recommend further evaluation at that point. Marcel |
Looks like another covered beam behind it.
Maybe that steel one was added for a remodel job above. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I doubt it!
Marcel |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mine from today.
From the picture, unless it is an illusion, it appears that a check crack has already started at the base of the electrical box.
But don' worry, they added solid blocking to beef it up. Marcel |
| Steel Beam Boring? | msylvester | Structural Inspections | 19 | 10/1/07 7:25 PM |
| Crack in Support Beam | Berry T. Wilson | Structural Inspections | 6 | 5/26/07 3:15 PM |
| Steel beam lateral support | Mark Ellison | Structural Inspections | 10 | 1/16/07 10:40 PM |
| Steel beam bearing 1 1/2" | scosta | Structural Inspections | 17 | 6/12/06 9:01 PM |
