Old 12/15/11, 2:34 PM
Joe Funderburk, CMI's Avatar
Smile Cut load bearing wall stud
A good issue to kick around here on the message board.
I did a pre-drywall inspection for a client and saw this. I know what i said, but was wondering everyone else's thoughts. Beam support consists of 8 2x6s. In the conduit is low voltage communication wiring I think. You'll see CSST and romex in the same area. Opening for conduit is 1.5 inches.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/15/11, 3:23 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Default Re: Cut load bearing wall stud
Joe
Option 1: The code limits notches in load bearing wall studs to 25% (1.375" in a 2x6). In this case the notch is slightly over the maximum depth.
Option 2: Could be considered a load bearing column. I would have to determine if the remaining capacity is acceptable for the applied load.
In your position you get to make the call, but I would take option 2.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
RUSSELL SHUEY's Avatar
RUSSELL SHUEY RUSSELL SHUEY is offline
1.5 is too big. 1.25 is ok.
https://www.facebook.com/StateCollegeHomeInspector
http://www.centreinspection.com
Centre Inspection Services proudly serves the following towns; State College, PA 16801, Bellefonte, PA 16823, Centre Hall, PA 16828, Spring Mills, PA 16875, Millheim, PA 16854, Boalsburg, PA and the surrounding areas.
Old 12/15/11, 3:30 PM
If you mean 1 1/2" deep, the notching would exceed 25% (1.375") of the width of the stud.
Larry Kage, CMI
231 929 3525
Old 12/15/11, 3:33 PM
Is it a notch or a bored hole???
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/15/11, 3:51 PM
The code:
IRC R602.6 Drilling and notching–studs. Drilling and notching of studs shall be in accordance with the following:
1. Notching. Any stud in an exterior wall or bearing partition may be cut or notched to a depth not exceeding 25 percent of its width.
2. Drilling . Any stud may be bored or drilled, provided that the diameter of the resulting hole is no more than 60 percent of the stud width, the edge of the hole is no more than 5/8 inch (16 mm) to the edge of the stud, and the hole is not located in the same section as a cut or notch. Studs located in exterior walls or bearing partitions drilled over 40 percent and up to 60 percent shall also be doubled with no more than two successive doubled studs bored.
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/15/11, 5:39 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
If you are doing a Code Inspection as a minimum don't forget.
Preface of IRC.
This comprehensive, stand-alone residential code establishes a minimum regulations for one-and two-family dwellings and town-houses using precriptive provisions.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/15/11, 6:33 PM
I would agree with Randy on his option 2 and the picture also seem to indicate that there is another bored hole for a romex wire in conjunction to the notching that was done.
Depending on the load and whether or not the multiples were added to compensate for the notching exists, I would refer to the Architect or engineer that designed the loading supports.
Old 12/15/11, 6:44 PM
James F. McKee's Avatar
there had to be a better way to run that cluster flub....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 12/15/11, 6:53 PM
There is usually always a better way Jim, this one was to convienient in lieu of what we call planning and coordination of the trades.
Old 12/15/11, 6:54 PM
Ya think ??....no cure for stupid partner....just no cure...
Jim Mckee
Amherst, Ohio
Old 12/15/11, 8:02 PM
Here's a better look at it.
The issue is this: is the stud notched OR bored? If it's a notch, it cannot exceed 25% of the stud depth. The opening clearly exceeds 25% so a code violation exists. If it's a bored/drilled hole, it cannot be within 5/8" of the end of the stud and it clearly is withing 5/8" so a code violation exists. Either way, whether drilled or notched, the opening is not compliant in my opinion.
2006 IRC R602.6 Drilling and notching–studs. Drilling and notching of studs shall be in accordance with the following:
2. Drilling. Any stud may be bored or drilled, provided that the diameter of the resulting hole is no more than 60 percent of the stud width, the edge of the hole is no more than 5/8 inch (16 mm) to the edge of the stud, and the hole is not located in the same section as a cut or notch. Studs located in exterior walls or bearing partitions drilled over 40 percent and up to 60 percent shall also be doubled with no more than two successive doubled studs bored.
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/15/11, 8:55 PM
Joe
What type of load required so many 2x6 studs?
Randy Mayo, P.E.
573-201-8162
Old 12/15/11, 9:15 PM
Bruce A. King's Avatar
Looks like one of those big 2 story living room walls.
I bet the builder has an engineer that will crunch the numbers to say its fine. Its a complicated area since it serves load bearing and stability functions for that wall full of windows. I would recommend obtaining an engineers letter on that.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 12/15/11, 11:22 PM
Originally Posted by rmayo View Post
Joe
Like Bruce said, 2 story great room wall full of windows. This is the best picture I have of it. Support in question is at left side of far left window. Part of it supports the header above the lower windows and part supports a header above the 2nd level windows. A lot of wood to replace.
Theodore Roosevelt
Joe Funderburk, CMI
Question about wall stud size pwiseman Interior Inspections 10 9/4/10 10:59 AM
Basement vapor barrier jfrederick Interior Inspections 10 2/14/09 4:54 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
