Home was built in 1985, seller cut a hole in the garage wall common to the house. He was making another Attic access. In the process he cut one of
the rafters. How should this be written up? Is this a serious structural issue that should written up in red? ![]() ![]() ![]() ![]() David An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Just frame it up like a dormer. See attached picture.
How does all this effect what was the fire wall?
They did have separation in the original design for a reason I'm sure. |
Hi David
I would suspect when cutting a rafter you are taking away some of the structural integrity of the roofing structure. I would call it out and recommend further evaluation by a qualified professional. Also the firewall in garage that separates the garage from living space is compromised with large sections of drywall missing. A garage firewall should consist of 5/8 inch type X drywall. The intent of the firewall between the attached garage and the living space is intended to slow the spread of fire from the garage to the living space. This is a safety issue and the firewall integrity needs to be restored. |
What Randy said. Nothings going to collapse, but take a half hour to make it right.
Not serious: "A roof rafter was cut through without providing alternative structural support to make up for the loss of structural support. Although this is not a serious structural issue, it is improper and the Inspector recommends correction be made by a qualified contractor." As per Bob and Gary, recommend that a hatch be installed using 5/8" type X drywall. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Thanks for the picture....
Codes or their enforcement must be a little diff in CA. We never see above-ceiling garage to house firewall like that in Port St, Lucie or Sebastian, FL.
Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
Thankyou Pete, agreed here
Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com |
Randy, how in the world does the image of a dormer frame apply here?
He's got an opening in the vetical frame of an attic area w/ a cut rafter. The cut rafter end does need support. But let's not frame a dormer for it And yes Kenton it is structural Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com |
I see a bunch of issues here that should be addressed.
What exactly is the firewall, the ceiling, or attic compartments? Wires in walkway access. Disrupted insulation Missing header for rafter support lack of sill plate for rafter overlay support Missing door closer if a compartment separation Improper walkway access Damaged or improper ventilation duct wrap and installation And that is only what I see from a small picture. ![]() ![]() LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Good detail Marcel.
Hope I never need to sell a house you inspect. |
Joseph
The load transfer concept of dormer framing is what I was referring to. He wanted to know what to do... the answer is transfer the load of the cut rafter through a double header to the adjacent rafters. That's the best advice I could give him based on his photos. |
Sorry guys but when it comes right down to it, he should be referring it to a SE for further evaluation and designed repair.
He is located in California, the land of litigation, where the home inspection report can be relied on by someone other than his client for years to come. State there is a defect, approximate location and refer it out to someone who can legally write a designed repair. CYA. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
| Is this a Defect? Some various pics attached | tspargo | Interior Inspections | 19 | 6/18/11 8:40 PM |
| Cracked Collar tie near rafter ..need advise | dnasser | Structural Inspections | 5 | 4/19/11 10:16 PM |
| defect pics wanted | mnelson1 | Miscellaneous Discussion for Inspectors | 5 | 3/9/07 11:05 AM |
| Need HVAC Pics! | hgordon | Inspecting HVAC Systems | 2 | 2/17/06 10:06 AM |
