I was inspecting this house this morning and the deck joists appear to be attached directly to the rim joist (house band) via deck joist hangers. There is a ledger board attached to rim joist with ledger bolts where the deck stairs are, but for only 36 inches (the entire width of the deck is roughly 15 ft.).
I haven't seen a deck installed like this, but I'm assuming there might be a support issue as well as water intrusion issues. Please advise. Thanks guys. |
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I don't see that.
The rim joist of the deck is attached to the house joist, but it is not to sole joist (i beleive for this vantage point). It even looks like they flashed it (hard to find around here)! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
It is flashed correctly.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Looks alright to me.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Look closer guys............
looks like they used screws on a couple of those hangers.......left hanger, left interior..... Can you blow that up any more.... Jeff |
And if you really want to get nit-picky, the lag bolts should be staggered...
Not being nit picky Jeff........if in fact they are screws then you should know that screws are not an acceptable method in attaching joist to hangers.
If nails there is one missing also, but that was not part of the question.
And the lags are wrong and what is that bolt for? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Didn't mean to infer that you are being nit-picky with the (possible) screws. I agree with you. My post was stand-alone to the lag bolts. I call out non-staggered lags. Many inspectors argue that it is not necessary to stagger, (as long as lags are used, good enough), and being nit-picky.
gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
I just finished a Pergola in the city of Burbank and if you are familiar with So. Cal you know they are very strict. I used two 1/2 x 5" lags 32" O C and did not stager them. The plan was engineered. I try to cover all my joist hangers and did use joist nails on the one even tho it was not called out on the plan. What to you guys have against screws
For you electrical guys under the artificial turf is the famous grid bonding system
The only equivalent to lags for ledger boards.
http://grkfasteners.com/en/RSS_1_2_information.htm View our RSS™ Promotional Video LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
| Family's house is infested with mold | rspriggs | Ancillary Inspection Services & Additional Topics | 6 | 1/28/06 2:05 AM |
