I turned up this picture during a web search, and would like to identify the author to obtain permission to use it (with attribution, of course, and a link if desired) in an article for my web site:
The link is http://www.nachi.org/bbsystem/usrimages/P/PA190077.JPG Thanks. |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What do you think caused that issue Michael?
I think frost when water freezes it generates 25,000 lb per sq inch.
In order for a 1/2 pipe to stand the pressure it needs a 2 inch wall . Awesome Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Looks to me like a lintel installed above a plugged through-wall AC opening expanded and lifted the sill. Hopefully, the OP will show up and tell us.
The area should have been maintenanced years ago. >The cause is from frost. The frost is caused by the migration of humid air into the wall cavity ,during below freezing weather and the vapors turn to frost.. The air is carried into the opening ( a crack,unfinished masonry joint , caulking that shrank,or what ever) between the walls and the warn side acauses draftup the wall and the cold side ( brick)attracts the vapors and turns it to frost. Also there is a flaw in the brick style. There is a ladder pattern just below the window with a stretcher bond above only 2 courses high with the lentil on top. More room for movement in the brickwork if there is a problem. And there was. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
On closer look the ac unit in the window is a custom skinny unit made for casement windows that I personally refer to as Florida windows because they lack proper sealing methods with only one latch in the middle. I am also noticing that the co axial cable is going through the window. Lots of possible water intrusion going on in what may be a CHA or project building. |
That is a buckling of brick a couple of courses below the window sill. I don't know what caused it. What's an "OP"? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Looks like a solid brick building, windows were filled in with brick veneer , And has just collapsed or shifted.
Other People
John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
This picture turned up as a result of a GOOGLE for "deteriorated lintel", and at least when viewed initially the damage is consistent with the appearance of damage caused by oxide jacking at a lintel left in place when a fill-in was performed (see the enlarged image, which shows what looks - to me, anyway - suspiciously like a corroded and expanded lintel immediately below the lifted masonry and sill). Freeze-thaw jacking is is being proposed as an alternative explanation - I'm hoping someone will hunt up the original thread so that we have a definitive cause. "OP" = Original Poster. Last edited by mthomas2; 10/11/10 at 9:11 AM.. |
Sorry I just came home from Thanks-giving supper dinner with my mother and was tired . Its a ('' SILL'' A ''WINDOW SILL'') sorry,not a lentil. Look at the ladder stack brick and notice the stretcher course above it -WERE THEY MEET--the bond is broken on 2 courses. stretcher bond and ladder bond have 2 common but joints meeting plumb. A weakened area. Bricks have a bond to make them strong. Flemish bond ,Irish bond, Stretchier bond, the way the bricks are laid in a course running horizontally. Dam I will learn to take picture out of here and show you guys what I mean one day by drawing on it and then put it back, but not now. Breaking a bond weakens the jointing and now you see what happens. Follow the butt ends (end of brick) joints see how they are staggered. Like in flooring and dry-wall placement. They must not be stacked on top of each other like in the ''ladder stack'' brick on top of each other perfectly parallel and horizontally. Ladder stack bond is the weakest bond in brick-laying. Place the stretchers and just 2 courses on top of that ( ladder stack element ) above ,and by placing it below a window element or ANY opening of the wall. Presto a perfect place for a problem to arise. AND IT DID. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 Last edited by ryoung7; 10/11/10 at 8:25 AM.. Reason: editing and adding. |
I'm referring to the location below the still and lifted masonry:
BTW,
This is a lentil: ![]() This is a lintel:
I have tried 3 times and I am having problem with my PC.
I will get back later before I through this sh-t in the garbage. 3000 computer nothing but a pain in the asssssssssss. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
every one excause me but this computer is going off line till fixed.
| First 10 members to post win the entire InterNACHI Inspection Graphics Library. | gromicko | General Inspection Discussion | 61 | 11/30/10 8:07 AM |
| First 20 members to post win How to Perform Deck Inspections book. | gromicko | Exterior Inspections | 41 | 12/21/09 9:23 PM |
| First 20 members to post win Structural Issues for Home Inpectors book. | gromicko | Structural Inspections | 64 | 12/21/09 9:05 PM |
