need to be insulated?
Your in TX.
No. Heat loss is proportional to the temp difference between the interior of the house and the crawlspace. 68 indoor temp is real close to crawlspace temps. Even in winter, when hvac ducts are in the CS the temp stays up there. The answer is "depends where you live". Insulation is always a good idea however. Necessary, not always. Air infiltration is a greater concern than "R" Value. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Only with a properly installed moisture barrier. Also the crawlspace needs to be well vented.
Properly sealed CS can also be "conditioned"!
The answer is NO, but that means "Not always", not "Not ever"! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| New advanced, online, video course on inspecting crawlspaces. | gromicko | Miscellaneous Discussion for Inspectors | 60 | 7/12/08 2:36 PM |
| cold climates: insulating floors w/plumbing above cold crawlspaces | kshepard | Plumbing Inspections | 6 | 9/26/06 12:09 AM |
| encapsulated crawlspaces | jclark1 | Structural Inspections | 5 | 2/26/06 4:54 PM |
