Old 6/23/06, 10:03 PM
Timothy J. Lower's Avatar
Timothy J. Lower Timothy J. Lower is offline
Default What do you think?
Between 6-8 inches has fallen off the corner of this stone foundation wall. I recommended that it be futher evaluated by a S.E.. The buyer had another inspector go through this home before myself and he had said and even wrote in his report that "there is no problems present with the foundation wall". So question is what do you think?
Timothy Lower
Centerville, Ohio
Old 6/24/06, 12:31 AM
Dale Duffy's Avatar
Default Re: What do you think?
I wouldn't recommend an engineer from what I can see.
Looks like the parge just fell away.
Old 6/24/06, 6:00 AM
Roy D. Cooke, Sr's Avatar
Typical 100± rubble stone foundation .No big deal.
Roy Cooke sr.
Old 6/24/06, 8:15 AM
David P. Valley's Avatar
That gap simply needs to be filled. Then a nice parge coating of mortar to upgrade those loose areas.
Structural Engineer is not required.
Old 6/24/06, 8:19 AM
rwand1 rwand1 is offline
Typical stone rubble construction. Even if there is minor interior deterioration stone rubble walls are usually quite thick so this is not a concern. Even if you recommend further evaluation I am not sure there would be to many PE's around with this type of construction knowledge.
Would I recommend further investigation? No.
Old 6/27/06, 10:03 PM
Believe it or not, my old man's house built in the 1930's was on a similar foundation and still the way it was back then. These stone foundations varied to like 3 feet at the bottom and tapered up to 12" at the top.
Very stable.
Water impermeable, well not quite, but adequate for those times, when exterior grade was done right. It was not that bad.
Marcel
Old 6/28/06, 12:42 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just about every second house around here has a stone rubble foundation. They are usually very stable and leak water like a sieve. We often see pieces falling of them and it is not generally a big issue. Repair is easy and never permanent. The concrete used originally was usually inferior to what is available today and the homeowner just has to live with it. I always recommend to clients that if they are considering finishing the basement maybe this is not the house for you.
Larry
Old 6/28/06, 5:03 PM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
nice wire nut connection in the top right corner
Old 6/28/06, 5:31 PM
...not to mention the "tape" on the duct work.
Old 7/3/06, 10:12 PM
Larry;
Haven't you heard of Duct Tape before?? LOL.
Marcel
Old 7/3/06, 10:14 PM
LOL...
Hey, nice new avatar Marcel.
Old 7/3/06, 10:40 PM
Thanks Larry, and you would not believe how long it took me to figure it out.
Now I need to learn how to post pictures, ha. ha. Maybe my 3 1/2 year old grandson can teach me. ha.
Marcel
