Old 4/13/10, 6:42 PM
Jeff L. Gollaher's Avatar
Jeff L. Gollaher Jeff L. Gollaher is offline
Send a message via Yahoo to jgollaher
Default Does this look right?
In the attic of a 1996 2 story home & I see this block of wood supported by 2x4's holding up the roof.
No brackets, just some toed in nails holding this.
just doesn't look right to me.
any thoughts?
Serving the Greater Sacramento Area
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/13/10, 7:48 PM
mnahrgang's Avatar
Default Re: Does this look right?
My guess is that it was a temporary support while they were putting the rafters up. The rafters will be pressing on each other, and there is likely very little if any load on the 2x4.
Others with more framing experience than I will likely chime in though.
Mark Nahrgang
www.HeyMark.info
Old 4/13/10, 7:54 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
I agree. Temporary support.
Old 4/13/10, 9:49 PM
Jeffrey R. Jonas's Avatar
Or someone doesn't know how to cut compound angles, and they're CYA with the 2x4.
Old 4/13/10, 10:11 PM
thanks for the input
Old 4/14/10, 12:23 AM
Jay C. Murray's Avatar
Jay C. Murray Jay C. Murray is offline
It looks like temporary supports. Any evidence that the bottom end of the 'bracing' is pressing down on whatever it's resting upon?
Without being there, I'd want to add a some language to my report that advised the client to 'monitor' the item and protected yourself.
Your Home Inspection & Wind Mitigation Provider
Jay C. Murray
Florida Home & Insurance Inspector Chapter Board Member
Licensed General Contractor & Home Inspector
Serving Port St. Lucie, Ft. Pierce, Stuart, Palm City, Jensen Beach,
The Palm Beaches, & The Treasure Coast
Old 4/14/10, 7:09 AM
Temporary support used while erecting and never taken out.
When framing a stick built hip roof, the members act against each other and is difficult to keep the ridge from moving one way or the other. Once the common rafter and the two adjacent hip rafters are in place, it is no longer needed.
Full evaluation of the framing structure is warranted to make sure the design did not intend to have a king post for some odd reason.
Attenttion required at the seat cut and span of the rafters along with pitch.
If unsure of what is being observed, recommend a qualified framing contractor to evaluate.
Old 4/14/10, 11:11 AM
Thumbs up Re: Does this look right?
Nice verbage!
Jay C. Murray
Old 4/14/10, 9:44 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
Actually it is not temporary..... its suppose to be there......it s way to catch the hip and ridge together........ I have built home in 5 - 6 different counties around Mech.....each require this type of support...... its a very common framing technique.
regards
Jeff
Old 4/15/10, 2:41 AM
If that were the case Jeff, it would at least be plumb. And if you need a king post to support the hip roof, something else is deffinately wrong.
Old 4/15/10, 6:32 AM
Marcel,
It viewed as additional bracing which as you know does not have to be plumb.....it can range from 45 - 90 degrees.
You see such bracing in the more elaborate roof systems..... I would say though that when we brace the hip/ridge intersection we cut two blocks in a shape (trapezoid or octagon) that gives the maximum support.
Do I think its needed.....typically no..... however at the same time I have also built homes where the architect required two LVL's for ridges.
Based upon my experience as a builder and in particular framing hundreds of homes including those which required such support by the BI...... I would not have called it out. While hips are not technically self supportive as some builders and framers put forth, they are extremely strong roofs.....especially the greater the pitch.
regards
Jeff
Old 4/15/10, 6:38 AM
I wouldn't have called out anything either, because it is not doing anything.
Maybe ones perception would change being able to see the attic as a whole in lieu of a picture.
Built a few hips myself Jeff in my hey days.
Old 4/15/10, 7:28 AM
You nailed it Marcel with the perception statement.....its always difficult to comment on one picture........ hopefully everyone can use this as a reminder to post as many pictures as necessary to give their piers a better view as to what they looking at including wide angle exterior pictures....especially when dealing with framing issues......there are so many variables that affect framing.
And speaking of framing, Basterd (Irregular) Hips are fun. Whenever I got to the roof system I always carried my master construction calculator in my tool belt.....when I felt lazy I would pull out the "framer's bible"......not sure if you ever saw one but they are awesome.... a must for the serious framer.
regards
Jeff
Old 4/15/10, 8:41 AM
Well, I could lone you mine, but it is getting a little fragile.
Look at the copywrite. It has a few miles on it.
Old 4/16/10, 3:52 AM
J. Christopher Weise J. Christopher Weise is offline
regards
Jeff
I don't know what the code states but my framers have always installed this kind of brace and I have had local AHJ's request it be installed when it wasn't present. I always would rather see a little more than a little less bracing.
