Old 8/20/07, 4:05 PM
sbenson sbenson is offline
Default Drywall firewall boundries in attic
Noted two foot wide pieces of drywall nailed to truss's along firewall in a town home built in 1983. I cannot locate any information on this type of fire barrier. ?? any idea's.
Old 8/20/07, 6:23 PM
Default Re: Drywall firewall boundries in attic
Well, with a 3 1/2" opening in the drywall, it's breached anyway....
What showed when you peaked into that breach? Was the block wall cut tight with no gaps below the top cord of the truss next to it?
Larry Kage, CMI
231 929 3525
Old 8/20/07, 6:58 PM
Block wall extended up past the truss. Truss was butted flush against wall. Roofline's from one unit to next was staggered.
Sam Benson
HomeSpec Residential
Quality Inspections for the Informed Consumer
www.HomeSpec99.com
Old 8/20/07, 11:06 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
First - is this intended to be a firewall or fire separation?
There is a difference between the two.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 8/21/07, 8:44 AM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Good point Claude!!
"Definitions:
Fire Separation means - A construction assembly that acts as a barrier against the spread of fire. (Note: A fire separation may or may not have a fire rating)
Firewall means - A type of firewall separation of non-combustible construction which sub-divides a building or separates adjoining buildings to resist the spread of fire and which has a fire resistance rating and has structural stability to remain intact under fire conditions for the required fire-rate time.
Fire-Resistance Rating means - The time in hours or fractions thereof that a material or assembly of materials will withstand the passage of flame and the transmission of heat when exposed to fire under specified conditions of Test and Performance criteria, or as determined by extension or interpretation of information derived there from as prescribed in the National Building Code.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 8/21/07, 11:31 AM
mthomas2 mthomas2 is offline
What's needed there depends: does that wall extend up above the roof and form a compliant parapet? If not, that gypsym borad is needed, but it's not correctly installed:
R317.2.2 Exception: A parapet is not required in the two cases above when the roof is covered with a minimum class C roof covering, and the roof decking or sheathing is of noncombustible materials or approved fire-retardant-treated wood for a distance of 4 feet (1219 mm) on each side of the wall or walls, or one layer of 5/8-inch (15.9 mm) Type X gypsum board is installed directly beneath the roof decking or sheathing for a distance of 4 feet (1219 mm) on each side of the wall or walls.
Old 8/21/07, 1:15 PM
Jeffrey R. Pope's Avatar
There is no "separation" requirement for the roof structure, only the wall, which is CMU and non-combustible.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/22/07, 2:51 PM
Unmoderated Guest
Again, beg to differ. If the block wall does not extend as a parapet above the roof, or above the highest roof if there are different heights, then horizontal protection is required on each side of the wall to achieve the required fire-resistance rating.
Old 8/22/07, 8:33 PM
If you disagree, show me your reference.
I am always willing to learn. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Nail pops at the base of vaulted ceiling-no roof leak kshepard Interior Inspections 32 9/9/07 2:06 PM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 7:29 PM
