Old 6/19/10, 1:44 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default engineered trussed over interior wall
These engineered trussed are over an interior wall that a client is asking if the wall below the center of these trusses can be removed. As you can see in the pic the trusses are of different types. I just want to check with everyone to see if anyone feels there is any issue with removing the wall below with these type of trusses. Thanks.
ID:	37562   engineered-trussed-over-interior-wall-pict0306-small-.jpg.JPG
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/19/10, 1:51 PM
James H. Bushart's Avatar
Default Re: engineered trussed over interior wall
What is under the wall?
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 6/19/10, 1:53 PM
Bob Elliott's Avatar
Why would trusses effect anything below.
They are there to hold the roof.
Does the wall support the trusses?
Old 6/19/10, 1:59 PM
It depends on the design criteria. There is more than one style/design of thruss there and it appears that some web members are missing.
Larry Kage, CMI
231 929 3525
Old 6/19/10, 2:06 PM
Banned
Call in a structural CET familiar with truss design......shouldn't need a civil P.Eng.
Old 6/19/10, 2:11 PM
mnicholet's Avatar
Floor joists running in the same direction of the wall (not doubled up under the wall). My concern is there is two types of trusses in the pic. Some (in the front) have vertical members in the center of the truss above the interior wall.
Old 6/19/10, 2:12 PM
mnicholet's Avatar
Thats the million dollar question
Old 6/19/10, 2:35 PM
Banned
If there are web members missing from the truss/es where the wall is to be removed, the wall may now be giving partial support to the bottom chord/s, strapping and ceiling drywall. Removing the wall in this case may allow sag to occur which could be quite serious if you're in a high snow load area of BC.
Old 6/19/10, 2:49 PM
mnicholet's Avatar
I dont believe any webs are missing, I believe they are two different types of trusses.
Old 6/19/10, 2:57 PM
Look at your 1st picture...the 5th truss in.
On the right there is a web member (coming down from the ridge on an angle), on the left one is missing.
Larry Kage, CMI
231 929 3525
Old 6/19/10, 4:47 PM
I agree Larry, those trusses have been altered or modified for a reason.
The is a variety here of a King post truss, A Queen Post Fan Truss, and A Fink (W) Truss.
Some are missing chords. The King post is only good for a 16' span also.
Old 6/19/10, 4:58 PM
mnicholet's Avatar
Great info, thanks for all your help! I can always rely on the best
Old 6/19/10, 11:01 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Mark
Just by your pictures the three different styles of trusses pointed out by Marcel indicates there could be three different spans or different loadings or maybe the builder worked for a truss company and got free leftovers... In any case you would have to start at the roof and follow the load path down to the ground for each truss. The kingpost trusses, closest in the picture, gives me the most concern, I would start with them. One word of caution you are way outside the SOP so any advice you give will put you personally at risk and your insurance company will not cover you.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 6/20/10, 3:22 PM
mnicholet's Avatar
Originally Posted by rmayo View Post
Mark
Thanks, I referred it to a specialist for further investigation prior to any modifications and or to ensure conventional future performance under and including live loads.
Old 6/20/10, 7:31 PM
Marcel Gratton's Avatar
Good question Mark!
Usually, trusses are same which make it easier to determine if support wall can be removed.
On The Level Inspection
Gatineau, Québec
2x4 engineered floor joists holding deck header bking Structural Inspections 1 1/27/10 9:10 PM
Engineered floor joist hangers mnicholet Structural Inspections 6 7/9/09 3:50 AM
Support for engineered floor joist btreacy Structural Inspections 2 8/13/08 8:39 AM
Unfamiliar newer floor structure -- span too long for engineered joists? fbartlo Structural Inspections 8 2/10/08 11:11 AM
