Old 2/23/06, 10:02 PM
Mike Pettitt Mike Pettitt is offline
Default Erosion under slab
Florida home - new construction - concrete block on mono slab. Heavy rains washed out about an 18" by 48" by 9" deep area of soil/sand from underneath the slab/footing on the front corner of the home. The home is complete minus a few finishing touches. What would be the proper method of replacing this soil/sand other than just shoving it back underneath. How can you get it compacted to restore it to the way it was. Sorry no pix.
Old 2/23/06, 10:13 PM
Dale Duffy's Avatar
Default Re: Erosion under slab
If it was my house I would want a concrete slurry grout pumped into the cavern.
Old 2/23/06, 10:25 PM
tneumann's Avatar
tneumann tneumann is offline
And have fixed whatever caused the washout to begin with....grade etc......
Jay Moge's Avatar
Jay Moge Jay Moge is offline
i agree. drill a hole in the slab at the shallowest point, build a "form" at the expossed edges, pour concrete and let dry. you'll never get added soil to compact the way it should. 'course Florida itself will never compact the way it should.
Old 2/23/06, 10:35 PM
Thanks all, kind of my thinking also.
Old 2/25/06, 12:06 PM
Robert J. OConnor's Avatar
I agree
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 3/6/06, 8:19 AM
The owners contacted the builders concerning this. The builders said they would merely use a tractor w/blade and compress the sand back underneath to fill the void. They asked me what I thought of this. I told them; not my choice but I'd do a little research and let them know. Would really appreciate your opinions.
Old 3/6/06, 9:15 AM
William J. Decker's Avatar
If the contractor won't budge, make sure the client has a very good warranty!
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 3/6/06, 10:53 AM
Thanks William, I'm still looking for opinions on whether this may or may not be adequate. We photo documented everything and they do have a ten year warranty on structural. Just want to know if I should advise them to push further for a more proper repair. I didn't state this before but it is on the front of the home (right side) but does not wrap around the corner.
Old 3/6/06, 7:23 PM
Once the problem of erosion has been corrected for any further problems in the future, other than pumped or pressure grout that I would not recommend, I would entertain what they call flowable fill. It gravity fills all voids and stabilizes voids to the natural state of what was there before without causing any upward pressures causing an unequal grade support. Flowable fill is usually available through any Concrete Supplier.
Just my nickles worth.
Marcel
</IMG>
Old 3/7/06, 5:44 AM
Originally Posted by mpettitt
The builders said they would merely use a tractor w/blade and compress the sand back underneath to fill the void. They asked me what I thought of this. I told them; not my choice ...
Not my choice either or the best option, as it could just wash out again and the soil will never be compacted the same as other soil under the slab. This could lead to some future movement/cracking, but may not be such a huge deal if a small area with a uniformly loaded slab. If it was my house I would want it grouted.
JMO & 2-nickels ...
Robert O'Connor, PE
Old 3/9/06, 5:44 PM
P.S. "Soil Cement" (simple mixture of backfill with cement and some water) is another good option for the repair, which is easy to handle for your average contractor. Gets worked in like stiff backfill and hardens like a weak concrete.
JMO & 2-nickles ...
Robert O'Connor, PE
Old 3/10/06, 12:29 AM
msaxton msaxton is offline
Robert, around here we call that mudjacking, even listed that way in some of the phone books, had it done to a patio years ago, still no problems
"If God was one of us, would he recommend a detailed analysis by a structural engineer for the world?"
Michael S. Saxton
http://www.duluthhomeinspections.com
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
supply in slab or walls? jeubank Plumbing Inspections 1 7/8/06 10:36 AM
erosion under slab Jay Moge Structural Inspections 3 1/23/06 9:40 PM
