Old 9/17/09, 8:39 AM
Michael Larson's Avatar
Default Excesssive CMU spalling
Anyone seen this before to this extent and want to propose a cause?
1983 modular.
Surface spalling on East and West sides of foundation.
ID:	31680   excesssive-cmu-spalling-1014-rose-046-small-.jpg.jpg
ID:	31681   excesssive-cmu-spalling-1014-rose-017-small-.jpg.jpg
Michael Larson
Hudson, WI
[/I]
Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America)
Old 9/17/09, 8:47 AM
Joe Funderburk, CMI's Avatar
Default Re: Excesssive CMU spalling
High moisture in the block. Looks like poor drainage from here. I'd warn about drainage and advise that they may have trouble getting any coating to stick and refer them to a paint specialist.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/17/09, 8:48 AM
Did you see any efflorescence?
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/17/09, 8:54 AM
No.
The inside looked fine.
I agree that moisture got into the block and froze.
The house may have been vacant last winter and unheated. The gas meter was locked out so there was not source of heat.
My other thought was that the block was painted when it was not completely dry and late froze and popped.
Michael Larson
Hudson, WI
[/I]
Old 9/17/09, 8:57 AM
bdoles2's Avatar
bdoles2 bdoles2 is offline
I'm assuming you meant east and west sides of the home. It looks as though the rear portion of the foundation is not painted/sealed, was there any spalling there - or just on the painted/sealed sides?
If the spalling is only on the painted (east/west) sides, then maybe the wrong material was used to seal the foundation, creating a deficiency in the foundation surface.
Old 9/17/09, 9:05 AM
What about the grade, Mike? It looks negative to neutral against the house. If you don't see the efflorescence, it may not be moisture however. I'd refer them to a painting contractor and move on.
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/17/09, 9:11 AM
Yes. Fixed. Thanks.
Good eye. The South facing side was not painted but the North side is and has no spalling.
Michael Larson
Hudson, WI
[/I]
Old 9/17/09, 6:25 PM
The home probably does not have gutters on those sides......resulting in water splashing against the block over a period of time.........during the winter this can be very problematic........the problem could also be attributed to a non-breathable sealer........, adverse chemicals being used to clean the block etc.....I would simply recommend that a qualified masonry contractor be contacted......
Old 9/17/09, 6:29 PM
There are no gutters but the house has been there for 26 years. The damage looks recent as all the pieces are laying on the ground.
Thanks for your thoughts.
Michael Larson
Hudson, WI
[/I]
Old 9/18/09, 4:12 AM
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
'...........if efflorescence crystals grow inside-the-surface of the unit,
it can cause spalling'
http://www.aggregateresearch.com/for...ID=82&MID=2360
Not saying this is what occurred w/that house,just that its possible.
Sometimes a homeowner/contractor will PAINT/apply sealer on blocks that have efflorescence without trying to clean-brush chtt off.
Old 9/18/09, 12:52 PM
Christopher Currins's Avatar
Someone may have got carried away with a pressure washer.
Christopher Currins
Certified, Licensed
Old 9/18/09, 1:33 PM
William J. Decker's Avatar
We had a record number of freeze / thaw cycles, last winter (and you are close to my area). Sometimes, paint will seal in water. I recommend penetrating silicone sealer rather than paint.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Interior Basement Wall Spalling bwooddell Structural Inspections 7 5/10/07 10:39 AM
Grey stains on sidewalk spalling kshepard Exterior Inspections 6 9/26/06 6:59 PM
