Old 2/21/07, 10:47 PM
kmcmahon kmcmahon is offline
Please Note: kmcmahon is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Expansion/Control joints in masonry wall
Can someone explain why any mason would fill control joints with mortar?
Did a commercial inspection of a 20 year old post office...buiding was comprised of a double wythe masonry walls, 12" block and 4" brick veneer.
They tooled the joint to make it appear to be an expansion joint, but it appears to be mortar...doesn't make any sense to me?
It's as hard as a rock...could it be a sealant that has just hardened?
Joints occur at every window...about every 20' or so around the entire building.
expansion-control-joints-masonry-wall-cohen-016.jpg   expansion-control-joints-masonry-wall-cohen-017.jpg
Old 2/21/07, 11:10 PM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Expansion/Control joints in masonry wall
Hey Kevin, with out seeing it "live" I would have to say it is sealant that has aged, quite common. Still "gives" without letting moisture in.
Old 2/21/07, 11:34 PM
Jeffrey R. Pope's Avatar
It looks like sealant to me too, but it could be either. As long as the horizontal rebar is not continuous through the joint, it will still allow for movement. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/22/07, 10:59 AM
thejnicki's Avatar
thejnicki thejnicki is offline
Just readhing here, but could those continuous lines be a part of the elevation look? Architects do staranger things..
Timothy Hejnicki
All-Specs Property Inspections
(707) 428-3544
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 6:25 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 4:05 PM
Fire wall tyeager Structural Inspections 38 8/24/07 12:17 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 11:48 AM
No Brick Ties - Wall Buldge Stew Structural Inspections 1 4/22/06 7:56 AM
