Old 9/20/09, 11:51 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Exposed footings
Thoughts?
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 9/20/09, 12:01 PM
Default Re: Exposed footings
I can't see the bottom of the footing but if that is inside the crawlspace and the soil below the footing in undisturbed, I wouldn't worry about it.
Larry Kage, CMI
231 929 3525
Old 9/20/09, 12:19 PM
rmaday's Avatar
It is as you describe. thanks.
Old 9/20/09, 1:00 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
What about the crack and water penetration?
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 9/20/09, 1:05 PM
Bob Elliott's Avatar
Was that vertical crack at the middle third location.
It may be a good candidate for Permaseal.
I should say drill and injection method.
Old 9/20/09, 6:51 PM
rmaday's Avatar
Obviously I called those out, my question was really about the footings.
Old 9/21/09, 12:49 AM
Unmoderated Guest
I wonder what will resist inward movement by the footing, which is usually accomplised by a floor slab. In the very unlikely event that the footing was formed with a key at the bottom, it might be fine, but if not, then something has to keep the footimg from sliding inward bue perhaps to soil pressure on the outside. Maybe the friction between the footing bottom and th earth is enough,,but vthat calculation is certainly beyond my area of expertise.
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Exposed Styrofoam insulation mellison Interior Inspections 6 8/4/08 4:45 PM
Exposed Tension Bolts Erol Kartal Structural Inspections 25 4/13/08 11:18 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
