Old 1/16/10, 9:31 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Finger joint 2X4
I have never seen finger joints in 2X4's. These were used in the framing around the stairs. Any problems?? Sorry about the poor photo.
Thanks!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/16/10, 9:42 PM
Michael Larson's Avatar
Default Re: Finger joint 2X4
Thanks!!
http://newstore.southernpine.com/images/ref212.pdf
Michael Larson
Hudson, WI
[/I]
Old 1/16/10, 10:51 PM
Thanks! GOOD reading
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/17/10, 7:34 AM
Can only be used in compression and one kind is manufactured with fire rated adhesive joints so they can be used in a fire rated system.
Old 1/17/10, 7:46 AM
Thanks! Some I will learn how to use a search engine!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/19/10, 10:25 PM
FJ's are excellent, I have been using them for along time..... they are not designed for bracing, top plating and as previously stated compression only (vertical).
I went from having to replacing 10% of standard studs to less than 1 stud per 500 of the finger joint studs.........I love them..... as does my drywall hangers.
Jeff
Old 1/20/10, 9:43 PM
Joseph W. Keresztury's Avatar
Joseph W. Keresztury Joseph W. Keresztury is offline
Buck, thay are used here in Texas by the Volume builders (Tract builders) and frowned upon by the custom builders and as a quality product by consumers, but it is a decent product with less bowing, twisting issues as previously mentioned in this post, especially for sheetrockers.
Joe Keresztury
JWK Inspections
Home Inspections in San Antonio,
Schertz, Cibolo, New Braunfels, Boerne
and all surrounding South Texas areas
www.jwkhomeinspections.com
Old 1/20/10, 10:32 PM
Thanks, Joseph
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/21/10, 12:23 AM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Thanks!!
Cannot be used horzintal or where they can get wet.
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
The Left Thinks Wilson's Finger Was a Weapon jmckenna1 Miscellaneous Discussion for Inspectors 2 9/15/09 9:37 AM
Glass block windows at expansion joint jmerritt1 Exterior Inspections 4 6/4/09 9:49 PM
Soft copper joint dbucknavich Plumbing Inspections 7 2/9/09 1:05 AM
Usage of Finger Jointed Lumber for Rafters and an OSB question koconnor Structural Inspections 8 5/6/06 1:15 PM
