Should there be sheetrock covering these areas. The areas are above the garage, bedrooms on the other side. House built in 2006. Three years old!!!!!!!!
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America) |
Fire separation is probably the garage ceiling. Was the access/pull down fire resistant?
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Is it complete down below and are the walls fire separated down below also? If the fire sparation exists for the ceiling and walls below the ceiling joists the fire separation is not needed above also. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
R309.2 Larry is correct.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I did not write it. For those reason's. I do not like it but that is the C***.
A Modular home built in 1986 had a one car garage under the Home. does this require a Fire separation? The basement is all open to the garage area there is wooden door at the top of the steps there is insulation in the rafters in the basement and nothing is covered with sheet rock. There is No separation from the garage and oil tank or furnace either.
C. Bollin |
In a nutshell, there must be fire seperation at some point between the garage and the living spaces. The oil tank, no issue. Have seen them in garages. The furnace, no problem if there are no return or supply vents in the areas open to the garage. JMHO. I'm sure I'll be corrected, if I am incorrect. Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I did write up the fire separation. I do think there is to be a steel post filled with concrete so a car can not hit the tank. I am not 100% sure on that so I did not write it up. there also should be a wall if the tank is with 10' of the furnace (there was not one).
C. Bollin |
Question along the same lines: Is OSB accepted as a firewall material?
I recently had a contractor tell me that is is accepted. -I doubed him. |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Garage fire protection question | bwooddell | Structural Inspections | 10 | 6/23/07 6:52 PM |
