Not sure if I have the right forum, but anyhow, here we go. My question pertains to the requirements for a Fire Rated Garage Door into the home. It is my understanding that a metal plated hollow door can be used as a garage door, but if it is a hollow door, it must be self-closing. Is this right, and could we elaborate on all the requirements for the different type acceptable doors, please? Thank you for your input.
| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Check your local jurisdiction - not all areas require the door to be self-closing.
In general, a 20 minute door is required. This can be a solid wood door at least 1-3/8 inches thick, or a rated (listed) door assembly. There should be a data-plate on the jamb side of a listed door. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
A non-rated steel 1-3/8 door is also acceptable. That's usually what you see.
IRC R309.1 Opening protection. Other openings between the garage and residence shall be equipped with solid wood doors not less than 13/8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors. P.S. Glass in the door is a no-no. P.S.S. Self closing not required around here. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
To be precise.. pedestrian fire rated garage door....
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
I know the UBC requires 1 3/8 door to be self closing and self latching. There should also be weather stripping to provide a smoke seal. That's the way it's done here.
Self closing is a requirement for proper gas seperation (carbon monoxide from car fumes) than for fire separation. The door is for fire separation. We do require a closer, but it is for gas!
Robert Manley 7 County Home Inspection, LLC 612-919-3844 www.7countyhomeinspection.com Thermal Infrared Certified |
| Garage firewall voided... | jfunderburk | General Inspection Discussion | 10 | 11/13/10 1:41 PM |
| Annual fire door inspections required in Cali? | bgromicko | California Inspectors | 9 | 7/15/10 1:54 PM |
| Builder made fire door suggestions...? | tdietrich1 | Interior Inspections | 16 | 6/28/08 12:49 AM |
| Fire Rated Garage Door? | jfunderburk | Interior Inspections | 3 | 7/21/07 10:01 AM |
