Old 7/6/09, 9:56 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Fire Wall
Should there be sheet rock covering this wall. Area is located over the garage. On the other side of those studs and insulation is the master bedroom closet.
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America)
Old 7/6/09, 10:10 PM
Jeffrey R. Pope's Avatar
Default Re: Fire Wall
Yep.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/6/09, 10:12 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Yup.
5/8 drywall, and fire taped, should provide 1/2 hour "burn time"
Old 7/6/09, 11:10 PM
We all know that!!! The builder says I am wrong. AHJ is looking at?
Thanks!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 7/6/09, 11:11 PM
Michael R. Boyett's Avatar
Nope....as long as the garage ceiling is installed correctly.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 7/6/09, 11:26 PM
Michael Larson's Avatar
Based on what we have been told I agree.
The assumption is made that the pic is taken from above a properly installed ceiling in the garage.
Michael Larson
Hudson, WI
Old 7/6/09, 11:41 PM
There are TWO attic accesses in the garage. Both have sheet rock covers, the openings are trimmed out with wood.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 7/7/09, 10:29 AM
Buck, this can become somewhat of a grey area and controversial as well. Technically, your recommendation to clad the wall pictured can have merit in certain situations. The garage ceiling should be 1/2", type X drywall and not have any improper penetrations in it. The wood trimmed scuttle accesses likely don't meet the separation/fire/smoke penetration requirements but this is often overlooked by the builder and accepted by the AHJ. So, you can recommend the scuttle accesses be installed to meet separation wall (ceiling) requirements or you can suggest the drywalling of the insulated attic wall like you did. Financially, the cheaper path would be to address the scuttle accesses. If they are built using wood trim then replacing that with a less/non combustible trim may be prudent and cost effective. I would imagine some type of Hardie trim product would work. Maybe others can add to or disagree with my thoughts. Bottom line is...you're right to question this scenario but it is common to millions of homes across the US and the builder is not likely to be open to changing the scuttle installation since the AHJ accepted it.
Old 7/7/09, 10:55 AM
My assumption (based on the info in the first post) was that the picture was taken from the "garage," not the storage/attic space above the garage.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/8/09, 1:36 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
I agree with Mike. It's fine as long as the garage has a ceiling which is properly installed.
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
