I have a previous client that is stating that any pooling on a flat roof is a defect and the roof and decking should be replaced.
There is a slight warping of the decking with no compromise of the weather barrier [the roof isn't leaking] nor is there any separation or curling of the Mod B. The roof is newer and was fully permitted and passed. What are your thoughts....? |
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If you are asking if it should be repaired based on a home inspection; No. It's not leaking. It is doing what it was intended to do. That is to keep the water outside. Just because they didn't replace/repair the damage below the new roof and it will not likely last as long, does not mean they get a new roof. As far as we know, the building was priced reference to it's age and condition. It's a "used car". You don't get new tires just because they are not balanced. Any pooling of water should be noted in your report but but thats it. The roof deck (below) should have been looked at... I assume they are going after you... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
APPLICATION INFORMATION FOR RESIDENTIAL ROOFING AND RESIDENTIAL ROOFING PACKET As of MARCH 1, 2009, the Building Code for Broward County was changed to the 2007 Florida Building Code with High Velocity Hurricane Zone Requirements. Quote:
Shallow pooling under 1/2" can evaporate in less than two days is not a big concern. Just notate it. |
It was minimal at best. Roof was installed prior to the revisions of building code. Roof was not leaking...and was fully permitted and passed final.
goldcoastinspect@aol.com |
I agree with Bob. Water should dissipate in 24 to 48 hours after a rain. If it pools longer it becomes a problem. Water weighs 8.35 lbs per gallon. If there is rotted wood or structural issue below, the water weight can cause possible collapse or further depression of roof surface.
Observe, describe the conditions. |
David
All flat roofs have some allowable deflection designed into them. So some ponding is inevitable. Maximum design deflection on flat roofs is typically check under the maximum rain and/or snow loading accounting for plugged drains. Construction tolerances will also contribute to ponding. If the roof was designed by and architect or engineer only they can give you the maximum allowable calculated deflection. In my opinion from a home inspector's perspective ponding just increases the potential for leaks in the ponded areas regardless of how long it takes to evaporate. I would just state" The flat roof has water ponding in areas or evidence of ponding. Although some ponding is inevitable on a flat roofs any ponded areas increases the potential for leaks." |
There is actually a roofing material that is guaranteed to not leak even if ponding occurs even on a seam. It is some type of white looking material reminds me of EPDM, and also there is a liquid application that is made by a different manufacture. The guarantees are something like 15 years.
So the customer saying that ponding is required to be corrected is not necessarily true with todays advancement in roof coverings. If needed, I can look through my reports where I asked the contractors after the repairs was made for the specs. I probably got them still laying in the pile of active reports that is a couple feet deep. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Water pooling on a roof is a deficiency in the system. It can cause leaks.
Flat roof expels water by slope ( runoff ) or by drainage. So the 0/12 roof has a slope to the drain. suspect: reverse pitch..When the building settles all the water does not enter the drain. Pooling. Recommend: licensed roofer re-slope the decking. Repair: all the BUR is stripped and all nails set. Insulation that is manufactured for slope to the drain is applied. BUR roofing applied or cold membrain. The problem is solved. http://http://www.homeimprovementhel.../flat_roof.htm montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Mr.Braun that product does exist. Its works but is expensive as compared to BUR roofing.
Its effectiveness is limited. 15 years. Not a long time. The public is trained to think that 10 years is effective for roofing systems. A well installed BUR roofing system lasts 25 to 30 years with maintenance. I have witness 40 years. I maintenance it for 25. Built in 1967 when my friends father bought it. 32 units. 4 fire walls. Plastic cement dries out and must be replaced or re-coated on outside and inside corners and flashing and coping seams. Gravel washes down drains and must be install with a wet-coat so gravel adter to the membrane.etc. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
This Company claims ponding is not an issue with the membrane.
http://duro-last.com/ DRAINAGE/SLOPE Duro-Last warrants its membrane even where ponding water accumulates. Duro-Last has found no adverse effects meets local building code requirements.on its membrane because of a lack of positive drainage, however, good roofing practices incorporate the use of positive drainage for the safety of the structure. The installing contractor is responsible to make sure roof drainage LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
Hello Eric, if you have the time I would appreciate a copy of the APPLICATION INFORMATION FOR RESIDENTIAL ROOFING AND RESIDENTIAL ROOFING PACKET.Thanks for your time,John
| Level of detail in the InterNACHI Roof Inspection Certification course/ advanced desi | kshepard | Roofing Inspections | 5 | 2/13/11 2:42 PM |
| Wind Mitigation and Flat Decks | mtyson | Florida Inspectors | 7 | 8/14/10 10:07 AM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| Flat Roof Inspection Question - White Color | rrunnels | Thermal Imaging, Infrared Cameras & Energy Audits | 23 | 2/27/09 7:51 PM |
| Flat roof question | rchorey | Exterior Inspections | 24 | 12/18/07 6:26 PM |
