Old 1/19/13, 6:22 PM
Sean Fogarty's Avatar
Default Floor framing help
Sideways 2x8 used for the ledger for the center girder. New constrcution in podunk.
Another new one for me. Will this work? I have seen it on a few small decks but this? I would thinks it lacked shear strengh.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/19/13, 6:31 PM
Default Re: Floor framing help
No, this is not a standard accepted ledger for conventional framing.
This ledger is at the mercy of the nail pull out values.
Old 1/19/13, 6:40 PM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is online now
That 2x8 on its side can barely hold up its own weight much less a floor. You should mention in your report the person that built this is too stupid to own a hammer.
Hardware stores should post the following sign:
"Anyone buying a hammer over 16 oz or an automatic nail gun will require a mandatory background check."
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 1/19/13, 6:47 PM
I agree Randy.
I also posted the wrong pics.
This one is more suitable.
As far as I can tell, that Builder struck out 3 times and is out of the game.
Old 1/19/13, 6:56 PM
Yeah, its been a real fun one. New construction mind you. One section had no strips or hangers.
865-256-5397
Old 1/19/13, 7:06 PM
Hard to believe that was new construction Sean.
It don't appear the new generation of Builders is going to get any better.
Old 1/19/13, 7:26 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I am going to go out on a limb and say it is wrong! LOL
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
apoteyes@gmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/19/13, 9:33 PM
William T. Misegades William T. Misegades is online now
The sad truth...
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Old 1/26/13, 3:43 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
That's an inadequate "girder", not an inadequate "ledger".
Kenton Shepard, CMI
Director of Green Building
INSPECTION SERVICES WORLDWIDE
EXPERT WITNESS SERVICE
Log homes - Unusual homes - Estates
Old 1/26/13, 3:11 PM
We don't actually see the girder, do we Kenton?
Old 1/26/13, 4:36 PM
Greg W. Mathias, CCHI's Avatar
Greg W. Mathias, CCHI Greg W. Mathias, CCHI is offline
I beleive Kenton you are only seeing the "ledger". Above that is a flush beam I presume. No hangers or proper ledger. Rip off the "ledger" and install hangers. Problem solved.
Greg Mathias, CCHI
Journeyman Carpenter
Level I Thermographer
Global Property Inspections
Lloydminster, AB. Canada
(780)205-9912
Old 1/30/13, 3:44 PM
Mark S. Tyson Mark S. Tyson is offline
Or the designers and AHJ
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 1/30/13, 4:13 PM
Right Marcel, it's an imaginary girder.
Kenton Shepard, CMI
Old 1/30/13, 6:17 PM
If I am right Kenton, it is not a girder at all.
The 2x6 appears to overhang for a 2" ledger and assummed to be 2" on the other side also, that leaves 1&1/2" for the middle.
They framed it with a single member.
Old 1/30/13, 6:39 PM
Good catch Marcel. What a crappy way to build a home. Now they need to install a three ply beam under that mess to hold it up.
Greg Mathias, CCHI
(780)205-9912
