Old 6/2/09, 8:55 PM
Joe Funderburk, CMI's Avatar
Question Floor joist blocking straps...should they be used?
Saw this on an inspection today. Didn't see any twisting. Thoughts? Should the straps be utilized? (What's the correct terminology to refer to these straps?)
P.S. The floor above is wood, if that makes any difference.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America)
Old 6/2/09, 8:59 PM
Default Re: Floor joist blocking straps...should they be used?
Yes, the bridging is 1/2 installed.
Larry Kage, CMI
231 929 3525
Old 6/2/09, 9:02 PM
Why is it required, Larry? Is blocking or bridging always required? If the straps hadn't been there at all, would that be a defect? (I probably wouldn't say anything if they were absent.)
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/2/09, 9:06 PM
They're used to make the floor more rigid. Was there a tile floor above?
I would just recommend completing the installation since it was started.
Larry Kage, CMI
231 929 3525
Old 6/2/09, 9:13 PM
There was tile and T&G wood. Correct.
I just feel bad for saying it should be completed, when if it had been absent I wouldn't have said anything. Looking for a reason that it is necessary.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/2/09, 9:37 PM
It may save the tile floor from cracking and keep the china from rattling.
Plus, like I said before, it is there and only 1/2 installed.
A recommendation to finish the job would be of no consequence.
Larry Kage, CMI
231 929 3525
Old 6/2/09, 9:39 PM
Joshua L. Frederick Joshua L. Frederick is online now
Joe,
I ran into this same deal a handfull of times. Why there not always fastened at the bottoms, I don't know. But anyway, here's what I've come up with:
Crawlspace: floor joist bridging
The metal floor joist “X” floor joist ties or bridging brackets were not fastened at the bottom and/or not properly attached in one or more areas. Floor joist bridging is critical to the structural strength of a floor. Proper bridging distributes the load on the floor to other joists and over time prevents floors from sagging and squeaking do to floor joists twisting and warping. Recommend repair and/or reattaching.
Old 6/2/09, 9:46 PM
Wayne B. Wilson's Avatar
Because they forgot to finish it after the insulation was installed . I write it up . If it isn't present i mention it there is several ways of installing it and it does stop the twisting and squeaks. I lot of builders will say it is not necessary but of course where are they when the problem occurs .
Old 6/2/09, 11:46 PM
William M. Corbett's Avatar
William M. Corbett William M. Corbett is offline
Some municipalities in my local do not require bridging. Alot of the builders do not complete the installation because they have had bad response from the home owner. The home owners have been complaining of squeaking from the bridging rubbing against itself. I have not experienced that problem personally. That is the info I've gotten from other builders.
Bill Corbett C.H.I.
Magic City Inspections LLC
InspectingtheUnexpected.com
Old 6/3/09, 12:04 AM
Most framers will bridge when spans exceed 12 ft,.......usually common with 14 - 16 ft spans and that being at the midspan point...............HOWEVER it is not required unless joist exceed 2x12 and then you can either bridge by cross bridging (also called diagonal bridging), solid bridging (shouldn't be offset) or a continuous 1x3 strip nailed along the bottom of the joist perpendicularly.
Bridging does indeed help distribute loads as well as reduce squeeks.
When one sees it incomplete than it is often because the framer inserted same from the top just before installing the floor sheathing but failed to jump down into the crawlspace to finish the job.
In this particular case it appears that the builder / framer simply picked up the wrong metal cross bridging.......those appear to be for joist 24 inches on center....not 16 inches.
regards
Jeff
Old 6/3/09, 12:15 AM
regards
Jeff
Good eye. I agree. wrong bridging
Bill Corbett C.H.I.
Old 6/3/09, 12:55 AM
Whoops! Report has already gone out!
Good eye Jeff.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/3/09, 4:46 AM
Joe,
While bridging is good to have.....and those spans appear rather long, probably 2x10x14 joists, based upon building code you are fine........its not something that is going to adversely effect the habitability of the home. (which is your escape if its ever brought up).
Worse case is to simply go back and install a 1x4 (1x3 are obviously uncommon) along the bottom and be done with it.
regards
Jeff
Old 6/5/09, 12:11 PM
What Jeff said. Bridging is an anti-rotation device, but mainly it encourages squeaking, which is even worse when they require midspan blocks. Wood cross bracing can squeak too.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 3/27/10, 12:32 AM
thorn2 thorn2 is offline
If bridging was part of original design it should be installed. It is a lateral bracing of the joist bottom chord. The joist has more load capacity if it is laterally braced on the bottom edge. Just because it is not twisting today does not guarantee it won't later. And remember the floor joists were design based on a 40 PSF floor live load (if it is a first floor). What if a pool table or something large was placed on the floor. You never know. Bottom line if it was there and intended to be installed why not just state for them to finish it? And yes, if it was absent to start with how would you know it belonged there? You don't, since you did not design it. There are a lot of redundancies in structural design so will it be a problem? Maybe never...I would have written it up. Seems like a waiving red flag.
Plates at rim joists with attached straps rharrington Structural Inspections 5 4/25/08 2:44 PM
Under roof straps gheller Structural Inspections 4 11/23/07 9:36 PM
copper pipes supported with steel straps bking Plumbing Inspections 3 9/11/06 4:01 PM
