Old 5/22/07, 10:41 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Floor joist support
Floor joist bearing on end of cylinder concrete piers. Some of the piers are moving around and evidence of movement in the home was observed. Wanted to get others opinion of placement of joist on this Pier. As you can see the majority of the weight bearing is on the exterior edge. I would rather see the floor joist sitting in the middle of the pier.
Old 5/23/07, 5:54 AM
Default Re: Floor joist support
Let's just hope the concrete doesn't spall off.
Not knowing what kind of weight this thing is carrying would determine whether or not it is adequate.
I would write it up accordingly James, and go with it.
It would not be adequate support in my book for long term.
I guess one could argue that they have three inches of bearing, but I think a third joist was added because the first two almost missed the Sono tube.
Marcel
Old 5/23/07, 6:38 AM
David P. Valley's Avatar
It's basically pretty simple... report what you see.
Observe & Report to stay out of court.Attachment 11753
Old 5/23/07, 12:14 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
there is a spec somewhere that governs where the bearing (joist, in this case) need to sit on top of the pier. i don't remember what that spec is, but your picture shows "nonstandard construction" and should be evaluated by an engineer.
Old 5/23/07, 7:17 PM
Book of Architectural Standards and Standards of the Construction Trade Practice Specifications.
Anything less is what they pay us to find, observe and report.
If it would not be for sub-standard work, I guess we would not be too busy inspecting conditions of the House.
That is sad for a new Construction and to be expected for older Homes for people that can't fix it or do not have money or the Famous DIY that thinks he is saving Thousands of dollars, until we show up. Man, we bad.
Marcel
</IMG></IMG></IMG>
Old 5/29/07, 11:53 AM
Robert J. OConnor's Avatar
The built up beam should be bearing close to the center of the pier. Some HI's use a 1/3 rule for inspecting piers and columns, where the bearing should be in the middle 1/3 of the pier for stability reasons.
Also if the edge of the pier cracks/spalls (it happens) there could be a total loss of support.
I agree with with others to write it up.
JMO
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Heavy timber posts and support beam hziegenbein Structural Inspections 4 9/24/07 8:22 PM
Floor support posts kgerhauser Structural Inspections 7 7/17/07 12:23 AM
cooler support ftingle Inspecting HVAC Systems 4 10/1/06 2:59 AM
Support post for Beam, is this right? mlong Structural Inspections 74 7/25/06 7:47 PM
