View Poll Results: Choose the most correct answer
No problem exists 19 16.38%
Too many large holes 20 17.24%
Not enough space between the large holes 5 4.31%
Not enough span from large hole edge to load bearing. 7 6.03%
problems are 2, 3, and 4. 53 45.69%
problems are 3 and 4 5 4.31%
problems are 2 and 4 7 6.03%
Voters: 116. You may not vote on this poll
Old 2/19/06, 10:41 PM
Bruce A. King's Avatar
Default Floor I joists
Picture from a pre-drywall (basement ceiling) inspection but could be found also on a completed house.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 2/19/06, 10:55 PM
twheeler
Guest
Posts: n/a
Default Re: Floor I joists
The only answer I would have is, "what does the manufacturers specification note with regards to hole sizes and spaces?
Old 2/19/06, 11:29 PM
Dale Duffy's Avatar
One would certainly think by looking at the engineered joists an issue exists.
But like Tyrone said, when an engineered joist is used, one would need to see the manufacturers guidelines regarding........
Drilling with a Chain Saw..........or very large Hole Saw.....
Old 2/20/06, 2:08 AM
ccoombs's Avatar
ccoombs ccoombs is offline
Please Note: ccoombs is a non-member guest and is in no way affiliated with InterNACHI or its members.
In general, my answer would be 2, 3, and 4. No I-joist manufacture allows that size or number of holes, period. However, I have worked with several I-joist manufactures to design floor joist for this exact situation.
As a home inspector or third party engineer this situation should be a read flag. Supporting documentation should be requested. Not doing so would be a liability in my opinion.
Old 2/20/06, 5:53 AM
Robert J. OConnor's Avatar
Since an HI is not certifying capacity or compliance, APA Guide #Z725 can be used as a general reference for I-Joists.
Actually that may be close to being acceptable (workmanship aside), as I-Joists generally can have multiple holes almost the entire web depth as long as they are not near an end and spaced with at least 2 x Hole Diameter of clearance (see page 16-18 of the APA guide available at www.apawood.org).
JMO & 2-nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 2/20/06, 1:33 PM
rwand1 rwand1 is offline
The holes look larger than allowed, and the holes do not look round indicating improper enlargement or knock-outs have been enlarged.
http://www.trusjoist.com/EngSite/lit...ex.cfm?#search
http://www.trusjoist.com/PDFFiles/2031.pdf
Downloadable pdf framers guide.
Old 2/20/06, 1:53 PM
Patrick Bolliger's Avatar
Talking Re: Floor I joists
Second joist from top of picture give you a clue (Right side).. These "holes" were field modified. Notice that the "hole" is not a perfect circle knock out.
At first I was thinking that the sizes maybe fooling since this "insulation" (looks like insulated ducting) maybe fooling but the spacing and number of holes, is just to much per the APA guide that Raymond's link posted.
Great info Raymond!
Floor a little "bouncy"...hmmmm
Old 2/20/06, 1:58 PM
This would be a good topic at regional meeting groups. I don't see many engineered floor joists, but some can be very confusing particularly when and where blocking is required, et ceteras.
Old 2/20/06, 2:00 PM
If there are too many large holes ( I voted for too many large holes) the whole joist is not safe. Hmmmm.
Old 2/20/06, 3:49 PM
twheeler
Guest
Posts: n/a
Truss Joists systems are not covered in the building code part 9, but rather is covered under manufacturers guidelines. Some truss joists come with webbing
Old 2/20/06, 4:16 PM
ccoombs's Avatar
There are too many variables in this situation. I work with a floor joist company that markets their product for these exact situations. They provide calculations, details, exact dimensions for hole sizes and locations, as well as shop drawings. Stating the floor system is “not safe” when this may not be the case undermines the client/homeowner’s confidence in builder and the home. Additional information is needed from the builder and/or engineer.
As for the floor joist with webbing, you typically can get a larger duct in the joist with a web.
Old 2/20/06, 4:31 PM
Too many variables = further investigation by structural engineer. By the photographic evidence it appears there is very little webbing left to maintain integrity. It would be interesting to find out if in fact these joists are up to snuff.
Old 2/20/06, 5:41 PM
Timothy J. Gardner Timothy J. Gardner is offline
There is a company here in VA that manufactures the cure for those I-joists.
Check this out:
http://metwood.com/span/reinforcer.htm
TG
Old 2/20/06, 6:07 PM
Timothy,
Thanks that is a great site, an innovative product! It appears that it can also be used on regular joists as well. This gives credibilty to my theory that notched or cut joists can be sistered without sistering running the full length of damaged/cut joists.
Thanks,
Old 2/20/06, 6:26 PM
William C. Martin William C. Martin is offline
I had an inspection that we questioned the I-beam joists. Checked with manufacture, e-mailed a few pics. They had a rep come by and look. It all checked out, but if you went by manufactures specs it was questionable.
Give a call, see what the manufactures says.
floor joists Kyra Bloom Interior Inspections 19 11/23/07 10:38 AM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
What's Wring With This Picture: Bored Holes in Floor Joists? homebild Structural Inspections 17 5/4/07 8:33 AM
Ceiling discoloration from joists? dtaylor General Inspection Discussion 4 8/3/06 12:27 AM
Cantilevered Joists Steven Brewster Structural Inspections 13 5/9/06 7:32 PM
