Old 5/10/13, 11:47 AM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Default Form Ties
Do any of you call out form ties which are not snapped off after construction? I mention it but am wondering if I should be more aggressive.
If so, what do you say about them, I'm in need of a comment.
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
www.homeinspectionpeoria.com
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/10/13, 12:32 PM
Default Re: Form Ties
bump
Cameron Anderson
Since 2004
Old 5/10/13, 4:05 PM
Bump
Anyone?
Cameron Anderson
Since 2004
Old 5/10/13, 4:20 PM
swaylandsmith1 swaylandsmith1 is offline
Please Note: swaylandsmith1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
If I see exposed ties I note that they should be removed and sealed to ensure no moisture penetration. To my self I say somebody doesn't take pride in their work.
Old 5/10/13, 6:06 PM
Bradley K. Toye Bradley K. Toye is offline
Forgive me, but I am not familiar with this type of "form tie"...looks like a CMU foundation to me, and why are the wall straps not fastened to the stem wall?
Old 5/10/13, 6:12 PM
Can you elaborate? What is a cmu foundation? I always want to learn.
Old 5/10/13, 6:20 PM
David Garton's Avatar
David Garton David Garton is offline
Concrete Masonry Unit (CMU) Construction
"If you work just for money, you'll never make it, but if you love what you're doing and you always put the customer first, success will be yours."
Ray Kroc
Old 5/10/13, 7:45 PM
Okay, I will google it and file the info. Thanks
Old 5/10/13, 8:19 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Form ties are designed to hold the concrete forms together prior to and during the pouring.
They are also designed to be broken off at the onset of form removal.
They beak to the interior surface of the wall where it can then be patch with a cementious product to achieve a waterresistant surface and prevent moisture intrusion via the form tie.
They are easily removed by hitting with a hammer to one side and then to the next.
Not to be confused with the type form tie here that was used in the late 60's where they had to be hit down and upward.
Those were called rabi ties and used 3/4" forms with steel walers.
Cyr Home & Commercial Property Inspections
Inachi Award Winner 2009
Old 5/10/13, 10:16 PM
Thanks Marcel, haven't seen that type. They use snap-ties mostly down here. That foundation wall form must have a simulated stone stamp on the inside.
Old 5/10/13, 11:06 PM
You have to look at the 4" siding for perspective. Those are two "courses" in the faux brick poured concrete foundation, about 7" of concrete showing.
Hey Marcel, thanks for the info. Anyone got a good comment I could borrow forever?
Cameron Anderson
Since 2004
Old 5/10/13, 11:33 PM
ROBERT YOUNG, CMI ROBERT YOUNG, CMI is offline
Send a message via Yahoo to ryoung7
I concur.
nice one Marcel.
I am going 25 years back on a country setting when I saw these. The home was built around EXPO 67.
Robert Young's Montreal Home Inspection Services Inc.
3510 rUE bENNY SUITE # 401
Montreal Quebec H4B 2R8
http://montreal-home-inspection-services.com
Unusual Things I have found rcooke Canadian Inspectors 894 4/29/14 5:41 AM
New wind mit form and OIR jshishilla Florida Inspectors 82 4/10/12 4:36 AM
Get the latest on Wind Mits, FL cont ed, inspector marketing, insurance inspections.. gromicko Florida Inspectors 34 10/25/11 7:55 AM
Who can inspect what? lcurtis1 Florida Inspectors 24 6/9/11 7:24 AM
