Old 11/27/09, 5:12 PM
tirwin tirwin is offline
Default Foundation crack
This is a 14 year old house with lever grading around the house. Do you consider these floor cracks a problem? They run from post to post.
Tom
foundation-crack-foundatin-1.jpg   foundation-crack-foundation-2.jpg   foundation-crack-foundaton-3.jpg
Find an InterNACHI certified Connecticut Home Inspector (and anywhere else in North America)
Old 11/27/09, 5:36 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Re: Foundation crack
They look like normal shrinkage cracks in the slab to me. The posts created a weak point in the slab, that is why the cracks run from post to post. Were both sides of the crack level or was one side higher than the other?
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 11/27/09, 6:05 PM
Tom
No, I don't. They look fine from Michigan.
Larry Kage, CMI
231 929 3525
Old 11/27/09, 7:05 PM
Looks good from Maine too!
Those have got to be the straightest wild cracking I've seen. Almost like they were controlled somehow by something we don't see.
The crack width usually tells me or indicates how wet the concrete was when it was poured.
This one was over a 5" slump.
I would recommend sealing the crack with an elastomeric sealant to prevent air from infiltrating the crack and causing slab curling, and also help for radon invasion of the space if that would be the case.
Old 11/28/09, 12:14 AM
Russel Ray's Avatar
Look okay from here in San Diego. If that house had been built in Rancho Santa Fe, they would have put expansion joints everywhere you see a crack, which would have prevented the cracks! Of course, such labor-intensive concrete work like expansion joints would have added $500,000 to the cost of the house. But, hey, you'd be living in Rancho Santa Fe!
Old 11/28/09, 3:39 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
probably a metal keyway under same.......looks good from NC as well.
Old 12/2/09, 1:04 AM
They probably poured the floor in sections using temporary screed boards to maintain elevation. Partial cold joists form when the screed boards are removed, and srinkage cracks form at these locations. That is why the cracks are straight. I don't see any concerns.
Old 12/2/09, 5:51 AM
David P. Valley's Avatar
Those floor cracks look controlled to me. Most floor cracks are no big deal as they do pour the floor after the foundation is poured.
Old 12/3/09, 4:27 PM
Both sides are level,
Old 12/3/09, 4:28 PM
Thank you
Foundation crack dokeefe Structural Inspections 7 7/4/09 11:47 AM
Foundation crack ? Jason Bloxom Structural Inspections 9 3/16/09 12:32 PM
Dampness in basement- new construction jcundiff General Inspection Discussion 47 6/21/08 11:35 AM
