Old 2/25/08, 2:13 AM
lolsen lolsen is offline
Question Foundation Crack How to report????
I inspected this 60 year old home and found this crack in the foundation. It ran from top to bottom, no displacement, and max width of 1/2 inch. The foundation juts out here as well (to the right of the crack).
As a newer inspector I never ran across this and was wondering how to report this.
Thanks
Lawrence Olsen
Universal Inspections
Old 2/25/08, 2:16 AM
Brian E. Kelly's Avatar
Default Re: Foundation Crack How to report????
Recommend evaluation by a foundation contractor with remedy as necessary.
Old 2/25/08, 5:41 AM
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
There`s a nice lil beauty....got milk?
Careful on those injections as about 50% will RE-leak. See other-
injection links `n pics posted...
http://www.wes.army.mil/REMR/pdf/cs/mr-3-9.pdf
-applications and limitations
Epoxy injection has been successfully used in the repair of cracks in
buildings,bridges,dams and other types of concrete structures.
HOWEVER, unless the crack is dormant (or the CAUSE of cracking is
REMOVED, thereby making the crack dormant), it will probably RECUR,
possibly somewhere else in the structure.....
and ummm, just because a crack seems/appears 'dormant' at that
point-in-time does not necessarily mean it won`t,can`t incur further
lateral pressure or other other pressures subjecting it to widen.
thats why its best to repair the dumb crack on exterior,and not to
recommend CHTT(injections,50% success rate) that doesn`t help
lessen,relieve exterior soil pressure or roots or possibly drive/patio slabs
or a porch footing etc.
http://www.bobvila.com/HowTo_Library...ion-A2095.html
...'often however, the biggest load on the foundation is not the weight
of the house, but the pressure of the SOIL around the foundation...
called the lateral load......'
http://www.Amherst.ny.us/pdf/buildin...S_section3.pdf
3.2 Lateral Wall Pressure
http://www.fairfaxcounty.gov/dpwes/p...rineclay.htm#2
Try `n save a couples pennies(injection) or go with TOMMY BOY`s brake pads
http://www.youtube.com/watch?v=8AaN0...eature=related
Survivor/I Can`t Hold Back http://www.youtube.com/watch?v=gu0T1...eature=related
Survivor/High On You http://www.youtube.com/watch?v=cck0r...eature=related
Old 2/25/08, 6:02 AM
David P. Valley's Avatar
Attachment 18888
Attachment 18889
Thanks
Lawrence Olsen
Lawrence,
With a crack that wide (especially located at the corner of the foundation) the decision is best left up to a licensed structural engineer.
Old 2/25/08, 7:36 AM
cgoyette cgoyette is offline
Please Note: cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
This crack is large enough and location make strongly recommeding a licensed structural engineer a must. Thats the only answer you should give.
Curt
Old 2/25/08, 8:22 AM
I agree Curt and David;
That is structural failure, and an Engineer will be required to evaluate the repairs and establish cause, before remedial repairs are anticipated.
Marcel
</IMG></IMG>
Old 2/25/08, 9:10 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
Curt
Agree!
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 2/25/08, 10:09 AM
Thanks Guys
There was no sign of leaks. Strange but true.
Thanks
Lawrence Olsen
Old 2/25/08, 11:39 AM
Thanks Guys
Thanks
Lawrence Olsen
Not all structural cracks will leak. I've had major foundation issues where there wasn't a speck a water.
"Click to Enlarge"
Either way, you now know what to do.
Old 2/25/08, 1:53 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
A structura;l evalustion may mean that an initial measurement is taken, and re-taken at monthly intervals.
It must be established if the cause of the crack is still active.
Referr to a structural engineer.
As to verbiage, I know that Porter Valley has excellent foundation verbiage.
Old 2/25/08, 2:19 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Please Note: Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
"Click to Enlarge"
Attachment 18890
ouch! I bet the seller didn't want to pay to have that fixed.
Old 2/25/08, 8:01 PM
Joe, both the pictures above indicate structural failure for the composite of the material used.
Any structural engineer that knows what he is looking at will diagnose the problem and come up with a remedial plan.
The plan will encompass the cause and what will be necessary to be done in order to repair which might mean takeing down a portion of the concrete foundation.
As for the block foundation, it is an I have seen in cases where the structural lateral failures will produce a crack as such and not leak water, and that is only because such instances will produce evidence to a good water proofing product on the outside that was able to bridge the gap of failure.
A good positive drainage and soil conditions could be an other possiblilty, but I wood doubt it.
Hope this helps.
Marcel
Old 2/25/08, 8:24 PM
Marcel,
Unless you are a professional engineer, you shouldnt be making structural evaluations. If you are, then you have a leg-up on the rest of us.
Rob O'Connor, a PE, may disagree with you on which course of action to take. I could have sworn alternate reasoning or commentary on cracks in the past... cracks that I would have sworn indicated structural failure, only to be corrected by Rob. So, for me, all bets are off.
I have also seen PE's not get too excited, if no lateral displacement is present, and actually use a crack gauge to establish measurements, then come back in 3 months, and if no further movement was detected, come back in another 3 months (or 6 months) before finally rendering an opinion or coming up with a solution.
My point in all of this is that our job is to observe and report.
Old 2/25/08, 8:30 PM
Peter C. Russell's Avatar
Joe, I would have to agree with Marcel, a 1/2 vertical crack in the foundation indicates failure, but a structural engineer should always be recommended in a case like this.
PS in most real estate transactions months of evaluation are not reasonable.
Old 2/25/08, 8:37 PM
Marcel,
Joe, I might not have the little piece of paper, but I do have the respect of hundreds of structural engineers in the State of Maine that I have built their foundations and erected their structural steel personnally.
I usually am complemented on saving their mistakes and coming up with solutions even. I also am well versed in geotech support for structural engineers.
In other words Joe, I am not quite your normal carpenter as you wish to see me as.
Thanks
Marcel
WA State Legislative update hmiller Legislation, Licensing & Legal Issues for Inspectors 153 5/4/07 11:55 PM
Foundation Crack Question thejnicki Structural Inspections 3 9/27/06 11:37 PM
Crack in foundation lfoster Structural Inspections 23 7/3/06 12:15 AM
