Old 4/24/08, 10:10 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Foundation cracks when carpet pulled up. Pictures included
I insected this house in Souther Calif. (Menifee) A track home less than 5 yrs old. When the buyer pulled the carpet in a guest room this crack appeared....Does this crack look to be a normal foundation crack ? It crosses the hallway and runs 9 ft in the guest bedroom before terminating.
Old 4/24/08, 10:25 AM
Michael R. Boyett's Avatar
Default Re: Foundation cracks when carpet pulled up. Pictures included
David...based on several sources, including my state's builder's oversight board, my level of crack tolerance is a generous 1/8" or even less if there is differential movement. While I don't see differential movement in your photos the width of the crack would certainly cause me to refer this to a structural engr or at least a reputable foundation firm to put a compu-level on it and take other measurements or observations to ensure the foundation was performing properly. My guess is that repairs are in order.
Old 4/24/08, 8:06 PM
The scale is a bit hard to judge correctly in the photos, but I would not be overly concerned by this crack. It appears to me to be less than 1/8 inch, and I also do not see any evidence of differential movement.
Old 4/24/08, 8:15 PM
Bob Elliott's Avatar
If it was the garage ,I might even congratulate the guy on being so lucky.
Old 4/24/08, 10:30 PM
thanks for the feedback
Old 4/24/08, 11:22 PM
Dale Duffy's Avatar
I would mention their normal shrinkage cracks from what I can see from the pictures, any slab here (or anywhere) which is not post-tension or saw cut to prevent cracks will do just as your pictures show----CRACK----
Old 4/24/08, 11:56 PM
Russel Ray's Avatar
The problem I have with that crack is that it's in a corner. Normal concrete shrinkage/curing cracks will be almost exactly in the middle of the slap, or in the middle of a stem wall. Inadequate rebar/improper rebar placement is typically the cause of corner cracks like that, so while I don't think it's a normal crack per sé, if one considers inadequate rebar/improper rebar placement to be normal, then it could be considered a "normal" crack. However, if there is inadequate rebar/improper rebar placement in that corner, which I suspect there is, then that concrete is going to do nothing but continue to crack and crumble. I think it should be taken care of now, while the carpet is pulled back and before someone goes installing wood or tile floors.
Cracks Above and Below Foundation Vents Skip Erwin Structural Inspections 5 10/23/07 4:27 PM
Cracks in rock veneer mmorgan Structural Inspections 20 8/25/06 10:06 PM
