Old 4/3/13, 1:02 PM
Larry King Larry King is offline
Default Foundation Cut and removed Why?
I have seen a-lot of firsts this week. Home built in 1978. Forclosed in 2012. Home has poured and concrete block foundation with basement and crawlspace configuration. Inspection of crawlspace area observed a trench dug along the wall of basement and a section of foundation cut out under front wall at garage slab. Foam board insulation was installed.
Any ideas why they would have cut foundation and removed such a large section? Seems like a-lot of work. Would it be for foam board installation? What would you recommend?
I have included photos and a "crude" drawing of area in question.
Let me know what you think.
Thanks
foundation-cut-and-removed-why-cut-out-foundation.jpg   foundation-cut-and-removed-why-foundation1.jpg   foundation-cut-and-removed-why-foundation2.jpg
Old 4/3/13, 2:40 PM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is offline
Default Re: Foundation Cut and removed Why?
Larry,
Was the cutout section of concrete, in the first photo, the section cutout of the basement wall for the access hole into the crawlspace?
The trench is the overdig left when excavating for the basement that was never backfilled.
The only issue I see is the garage area is usually backfilled with gravel before pouring the garage floor. I don't see any backfill material looking under the garage foundation wall.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 4/3/13, 3:06 PM
Hey Randy,
The cut out concrete was from the wall of crawlspace below/at the gararge floor slab.
Old 4/3/13, 3:19 PM
Christopher Currins's Avatar
Originally Posted by jjonas View Post
PDF won't download.
It did for me. Here it is in jpg.
CBC HOME INSPECTIONS
Christopher Currins
Professional Home Inspector In Edwardsville, Glen Carbon, Godfrey, Maryville,
Fairview Heights, O'Fallon and surrounding areas of S
outhern Illinois
We Make It Safer
Old 4/4/13, 12:20 AM
ROBERT YOUNG, CMI ROBERT YOUNG, CMI is offline
Send a message via Yahoo to ryoung7
I opened the download.
It looks like venting.
If you see no signs of installation for wiring or mechanical fasteners for equipment, I will go with venting the partial foundation.
Question I would ask myself.
Any windows in the basement?
Any signs of high RH, efflorescence, water staining or past flooding?,
Any bad weather for freak storms? is the trench in the crawl space you speak of look like water ran a course?
Was that used to empty a water dam in the crawl space.
IMO You are a solid HI without a doubt. I would write up what I observed and move on.
Hope that helps.
All the best.
Robert Young's
Montreal Home Inspection Services Inc.
Montreal home inspector - Montreal Building Inspector |
Inspecteur de la maison de Montréal Inspecteur en bâtiment Montréal
