I have a personal interest in this situation... it's my house!!!
I have two vertical cracks in my poured basement walls. The cracks are spaced far apart and only one (near the day-light corner of house) has settled. The bricks on the front of the house have cracked and opened up, the trim board joint at corner of house has kicked out... all the classsic signs of a foundation failure. I know it will be costly so I will get several estimates. Does anyone have any actual experience with companies that repair foundations? Best method? Warranties? Etc., My house is a brick ranch, approx 2800 sq ft, with full basement. Any comments would be appreciated. Oh, I know the $$$ will be high but what kind of costs have you seen. When I finally have this repaired I plan to take lots of pictures. I think it would make a great presentation on why to hire a HI. Thanks in advance. Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices Last edited by rnewland; 10/7/06 at 2:19 PM.. |
Robert,
Get ahold of Ram Jack for a repair quote. I used them six years ago for a slab failure. Here is the Arizona link, but their all over the country. http://www.azrm.net/ Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Any verticle displacement? Bowing of the wall? If soil/water pressure is the problem you may need an excavator to dig out expansive soil rather than mud jacking to raise a sunken section.
Pretty knowledgeable company and they give free quotes and advise (for Roberts issue, what ever it might be). There was a home here for sale for over a year, with no takers, the mono-slab failed miserably. Ram Jack installed 6 piers for $38,000.00 with a lifetime guarantee. One portion of the home was built over buried construction debris in a corner lot. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
No I haven't Dale, and I know some of these foundation contractors get pretty knowledeable after a while.
Mostly I'm just curious about what's happening with Robert's house. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Hi. Robert, any pictures?
That might help us in helping you figure this out. Marcel |
Sounds like the saw blade nick in the wall turned into a control joint. Unfortunately, it did just what it was supposed to do!
Some kinds of clay expand with moisture and don't shrink after drying. If you have that kind of clay in the soil around your home, the water leak might be the source of your problem. http://websoilsurvey.nrcs.usda.gov/a...oilSurvey.aspx will take you to a site similar to Google Earth from which you can record the general composition of the soil around your home. It might at least give you a rough idea about clay content if you don't already know. If that's the problem, sounds like a half-day with a backhoe and some non-expansive fill. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Assuming the the left side of your house is West, their seems to be quite a drop in grade in that area. Was that the area of the underground water leak? I know these questions might seem intrusive, but are required to help you and make a better conclusion as to what caused it. Any information on this board is free. ha. ha. Next best, hire local Geotech Civil Engineer and Structural Engineer to evaluate. $$$$$$$$$$$$ Trying to help. Marcel </IMG></IMG></IMG> |
Tort law generally provides for filing of a suit up to 10 years from the date of occurrence or 2 years upon becoming aware of the structural deficiency. (Your particular State Law may vary) The failed water main eroding the soil under the home may have caused the condition that is present at this time. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
We have good old Ga red clay
RWN,
Sorry to hear of your problem. Many of my clients have had get sucess with http://permapier.com/ I don't know if they are in your area but may be worth a shot. Good luck, ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Helicles work like a charm, but they can be expensive. I'd get three bids from experienced foundation contractors.
Thanks for the suggestions. I'll get 3 estimates for sure.
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Nachi, The Foundation and Estill County Ky | psabados | Charitable Organizations | 2 | 11/14/06 5:53 AM |
| Draw inspection " Foundation electrical" question | lgongre | Electrical Inspections | 8 | 10/29/06 1:26 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
