I would like some info on this type of foundation. Maybe a cutaway pic. Something that shows whats going on behind the bricks? Sometimes this wall is 3 ft high. Do they just pack dirt to raise it that high and then pour the pad? Is it still slab on grade, or called something else?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Mark, I believe that you are describing a stepped masonry foundation that is built on a slope.
Try these resources for more info.: http://www.ornl.gov/sci/roofs+walls/...NL_CON-295.pdf http://www.hometips.com/how-it-works...ion-types.html |
If you have a concrete floor that is a slab on grade. The footers can "step" as needed and still have a "slab on grade". The "grade" in this case is backfill.
Hopefully they did proper compaction (not likely) and/or installed footers under the load bearing walls or at least the major point loads. The top header block is an L-shape in most cases but that does not look like header block. Look for large gaps between the carpet and baseboards where the slab may have settled on older homes. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
If there's no basement or crawl space, then it's a slab on ground, and if there's no space on the other side of the foundation part, then either it's all natural soil, or it should have been compacted fill. Sometimes they just fill with crushed stone to save the time and cost of compacting.
no basements or crawls, thanks for the info
Richard, nice links thanks.
| Dampness in basement- new construction | jcundiff | General Inspection Discussion | 47 | 6/21/08 12:35 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
