Old 9/1/11, 6:59 PM
Sean Fogarty's Avatar
Default Foundation removal for HVAC
Now before the debate begins, I am well aware of what the "Correct answer" should be. I also know that many of you don't get the pleasure of being able to inspect anything over 50 years old except on a rare occassion, and you don't get to see the great and creative ways some of the older homes were build in the land of the inbreeder.
I have looked at tons of houses with this same type of installation. It is an acceptable practice around here, (on older homes) and I have yet to see one with the first sign of a problem.
What is your opinion on removing the block to make room for hvac ductwork without first installing a lintel or support of any kind.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/1/11, 7:44 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Default Re: Foundation removal for HVAC
it looks like a mess from here
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 9/1/11, 8:18 PM
Jamie R. Wilks's Avatar
Jamie R. Wilks Jamie R. Wilks is offline
Sean
Like you said, we all know the answer. The foundation wall should not be altered without having some type of support to span the opening. I know I have and many others have seen it done without the support. I note what I see and how it should be, but what's done after that is most likely nothing. Most people leave it as it is, I rarely see any additional support added.
Jamie R Wilks
North Star Home Inspections
VCHI #3380000351
InterNACHI #05081596
Old 9/1/11, 8:22 PM
Originally Posted by jwilks View Post
Sean
Glad to know the epidemic is nationwide.
865-256-5397
Old 9/1/11, 10:13 PM
Robert J. OConnor's Avatar
Probably just enough support between the sill plate and rim joist or header (assuming there isn't a splice right there), combined with the sheathing to just span the opening. Doesn't mean it isn't hanging on by a thread and one unusual wind/seismic even will cause a failure. Should get flagged every time.
JMO & 2-Nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 9/2/11, 12:26 PM
pcooley pcooley is offline
Please Note: pcooley is a non-member guest and is in no way affiliated with InterNACHI or its members.
i liked the electrical wire with bare ends wrapped around the metal strap
Old 9/2/11, 4:13 PM
Kenneth R. Brittain Kenneth R. Brittain is offline
makes you wonder whats the difference between this and the crawl space door? A lot of doors are built with out a lintel support. Plus most crawl spaces in my area are pier and curtain walls so most of the support is being done by the pilasters and not the curtain wall
Old 9/2/11, 6:31 PM
Other than a HVAC duct work mess, improper wire support, improper pipe support, and other things we don't see, I see no need to get alarmed with a box sill spaning 2' +/- over an opening like this. Been done like this for hundreds of years.
Although it don't meet today's standards in framing an opening under a residential floor, it will not collapse because of this opening.
I would be more concerned about everything else around it.
You might get concerned though when you see something like this;
Make head room for a garage door on a commercial building.
Make room for headroom by cutting out the barjoist, hell, the wall will carry it.
Well the floor was not strong enough to support the storage above because the floor joist span was to great for the condition, so lets reiforce it with a beam.
Now this is when a concern steps in. And guess what, that was an automotive parts storeroom above and been like that for I don't know how many years.
I told the client, I am sorry, but this needs an evaluation by a structural engineer, which I don't do very often, but like I told her, even though it has been like that for many years, dosen't mean it will not fail the minute I walk out the door. She said, I understand your position.
Old 9/2/11, 6:43 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Nice!
You win the defect of the year award!!!!
I will send you your prize as soon as you correct the problems Marcel. LOL
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/2/11, 10:23 PM
Joe Funderburk, CMI's Avatar
I see brick veneer walls penetrated every week for a package system. I always call it out, recommending a lintel.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/3/11, 12:05 AM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Originally Posted by sfogarty View Post
Now before the debate begins, I am well aware of what the "Correct answer" should be. I also know that many of you don't get the pleasure of being able to inspect anything over 50 years old except on a rare occasion, and you don't get to see the great and creative ways some of the older homes were build in the land of the inbreeder.
What is the exterior envelope made of first of all?
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 9/11/11, 8:49 AM
No header/lintel is also a common issue in my area where an addition with a crawl space is added to a 2-story house with a basement and the crawl space access is an opening in the old foundation wall. Should get flagged every time.
Robert O'Connor, PE
Old 9/11/11, 1:49 PM
Originally Posted by roconnor View Post
No header/lintel is also a common issue in my area where an addition with a crawl space is added to a house with a basement and the crawl space access is an opening in the old foundation wall. Should get flagged every time.
Robert, you tell us that a hollow block traverse to a beam is adequate for support, but here you say that a lintel is necessary for a block opening with no masonry above it.
You confuse me, cause now you are saying that a 2"x6" sill plate with a 2"x10" box header can't span a small opening of 16" to 30"?
They are all over the place and never seen one collapse yet.
Old 9/11/11, 2:58 PM
Originally Posted by mcyr View Post
Robert, you tell us that a hollow block traverse to a beam is adequate for support ...
Absolutely, if it has the required pier cap and meets other limitations like height ... no doubt at all
... but here you say that a lintel is necessary for a block opening with no masonry above it.
I meant for an average 2-story house ... fixed. A span of just 16" would likely be okay (no sill/header splices). That opening wouldnt accommodate typical ductwork or the minimum 24" wide crawl space opening. I typically see those openings 32" to 36" wide. Commonly a 2x8 rim joist, or 2x10 for wider houses, would not span that ... see the IRC Header tables for a 2-story house.
Visual appearance or something not collapsing has absolutely nothing to do with structural capacity (unless it's really bad) ... or having appropriate safety for things like unusual events and common material defects like checks in wood (called factor of safety).
Robert O'Connor, PE
Old 9/11/11, 4:01 PM
So would this work?
Header over foundation opening
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 11:45 AM
Dampness in basement- new construction jcundiff General Inspection Discussion 47 6/21/08 11:35 AM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
