Morning everyone,
Inspecting an A frame this week. Are there any particular areas of concern with this type of contruction I would want to pay particular attention to?? Thank you |
Moisture in the walls from stack effect! This type of home is like a tall chimney and if there is any air coming in on the bottom it will go up through the wall cavity out the top. Check all the base design to see any signs of staining on the drywall or wood and test for moisture if you have a contact moisture meter. If they have a central located Wood Stove check for double wall chimney vent and connections at the ceiling line.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Mold in Foreclosed Homes | dplummer | Ancillary Inspection Services & Additional Topics | 2 | 3/16/09 8:53 PM |
| Healthy Homes Specialist Credential being offered. | gromicko | IAC2 Indoor Air Forum | 0 | 2/12/09 4:44 PM |
| Buyers of pre-owned homes sue builders | dplummer | Ancillary Inspection Services & Additional Topics | 1 | 2/7/08 9:34 AM |
