Old 1/14/12, 11:51 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Framing Question
I found this framing in a hip roof this AM. I do not now everything yet, so can some help me out? Is J. Haynes on the board?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/14/12, 12:01 PM
Nick Gromicko's Avatar
Default Re: Framing Question
I don't see a problem. Is it the ridge supports that you don't like?
Find a Home Inspector
Old 1/14/12, 12:39 PM
Thanks, I am concern about the round connections.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/14/12, 1:14 PM
Leonard Inkster's Avatar
Leonard Inkster Leonard Inkster is offline
Send a message via Skype™ to linkster
In Canada, this would NOT be considered structurally sound.
The studs are sistered with angled cuts that don't appear to be supporting anything, there's enough nails up there to seal up the hole in the Titanic, and WTH are those octagonal shims supposed to be doing? Providing an easy means for the studs to slip off and poke through the roof covering when it collapses?
I'm not even going anywhere near the way the vent pipe has been supported.
Was this the construction crew that built the house
Future Proof Property Inspections
Leonard Inkster, CHI, IAC2
Proud NACHI Certified Member
Web: http://fppi.ca
Mail: leni@fppi.ca
oovoo: Len Inkster
skype: leninkster
facebook: Len Inkster
You can't depend on your eyes when your imagination is out of focus. (Mark Twain)
Old 1/14/12, 1:50 PM
Leonard,
That is why I asked. I have never seen anything like this, myself. House is 4 years old.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/14/12, 2:37 PM
I have seen many types of props for hip roof framing before, but this one is an original.
Old 1/14/12, 2:40 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
See it often here.....
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 1/14/12, 3:06 PM
Well if you do Robert, why done in that fashion?
Old 1/14/12, 3:29 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Personally I have only seen that style in light structures like a gazebo. Generally it has one point load in the middle so a round or octogon piece of plywood ties all rafter ends together and if a support post is needed it is nail or bracketed to the plywood.
The picture is all I can find of a Pentagon design.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/14/12, 3:46 PM
It really caught my eye too the first time I saw it. Now it seams to be a common occurrence on newer construction. My guess is it provides more surface area support at joints to aide with construction.
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 1/14/12, 4:02 PM
Just seems like a weird way of doing it. But to each his own I guess. They should no longer be needed for support at this time though. Wondering why they were left in place.
Old 1/14/12, 4:54 PM
Bruce A. King's Avatar
Hip roofs are not self supporting as believed years ago. The proof is all the old sagging ones we see. Those supports are needed, they just use the block to hide the joints above and help spread out the support post to all of the adjacent rafters. If nailed properly, its fine as is. If something happens to knock those loose the homeowner will have much more to worry about than just the roof.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 1/14/12, 5:19 PM
All I can say Bruce, is that all and every Hip roof I framed over the years, did not need a ridge support.
If it is required, something else outside this picture is causing the need for those supports.
One should be able to identify whether or not they are required to prevent sagging during the the inspection, if not, recommend a qualified Framing Contractor or an Architect to determine.
I have seen plenty of old homes with hip roofs and dormers without sag in this area. No props for the ridges.
Old 1/14/12, 5:29 PM
KEVIN WOOD's Avatar
Here too Marcel! If built correctly the structure is supported by the Jack rafters and hip that spread the forces along the ridge to two points loads.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/14/12, 6:16 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
I agree with Marcel a simple hip up to a certain span is usually self-supporting. Current roof designs are no longer simple, but are broken up with multiple gables coming off in all directions. I-joists & LVL hips are sometimes used to get longer spans than you could with lumber. Wind design requirements have also become tougher in current codes. For all these reasons it's easier to design a hip roof using beams and support posts then designing a self-supporting hip roof.
Check out this article to see some of the rafter and hip details for a small but complicated self-supporting hip roof without ceiling joists. http://www.mvconstruction.com/roof_article.pdf
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Attic framing...beam question jfunderburk Structural Inspections 10 6/3/10 6:23 PM
gable end framing question rdemott Exterior Inspections 6 3/27/09 8:26 PM
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Plumbing vent Routing Question kweiss Plumbing Inspections 7 11/1/06 9:57 PM
