Old 2/2/08, 10:34 AM
Mark D. Schniers Mark D. Schniers is offline
Default FRP Plywood
Other than color change and deterioration, how can one identify FRP plywood? Is it embedded in the APA identifying code stamp?
Old 2/2/08, 3:14 PM
Unmoderated Guest
Default Re: FRP Plywood
FRP to me is Fiberglass Reinforced Plastic. That's the danger of using abbreviations and non.generic terms. I assume you're referring to Fire Reistant Plywood. If it is stamped at all, it would be stamped by the processor who applied the fire-resistant chemistry, and not by APA, which would stamp the grade of plywood but not any subsequent treatment.
Old 2/2/08, 5:30 PM
Hi. Richard and yes that is confuseing.
Typically, FRTP is the common abbreviation for fire retardant treated plywood.
Here is a link that might help mschniers post above.
http://www.cwc.ca/NR/rdonlyres/77351...reatedWood.pdf
Hope that helps.
Marcel
Old 2/2/08, 6:27 PM
Randy D. Stufflebeem's Avatar
Randy D. Stufflebeem Randy D. Stufflebeem is offline
Hope that helps.
Marcel
arcel,
Marcel
Thanks for the link. You always seem to have the right ones!
Randy
What Happened Here Tile Roof Plywood Decking pmagrone Exterior Inspections 21 7/19/07 2:08 PM
Attic Plywood gporter Interior Inspections 13 5/30/07 2:31 AM
Plywood mixing box? djones6 Inspecting HVAC Systems 1 4/5/07 1:22 AM
Treated Plywood ? Homey Structural Inspections 4 3/23/07 3:10 AM
3/8" plywood roof sheathing kshepard Exterior Inspections 12 8/15/06 8:28 PM
