Is the delaminating plywood FRT? There was a new roof installed and only about 25% of the original sheathind was removed. It appeared that they installed the plywood over the 75% of the other sheathing that may be FRT.
I know the origianl sheathing is a ***** to remove as it breaks into little pieces. Thanks Dave |
Dave,
You should see a manufacturers stamp on each sheet if it was. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Assuming it was an attached dwelling, the FRT would usually run 4' and 8' alternating in from the partition wall.
I can't imagine many of the bad batches of FRT plywood are still installed, but there are always surprises. |
Most of the FRT I've seen has a whitewash look to the surface and every sheet is cleary stamped.
Even when I installed reg. ply and used FRT coatings I had to have a stamp made and label every sheet before we could get the final and CO. http://www.inspect-ny.com/structure/FRTplywood.htm ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Senthil Puliyadi is a non-member guest and is in no way affiliated with InterNACHI or its members.
What is "FRT" by the way?
http://www.inspect-ny.com/structure/FRTplywood.htm or it can also be the affliction caused by copious legume consumption.
Hi Dave,
the color of that sheathing combined with its delamnation does sound like FRT, as other have said it should be marked, but when it degrades the label cannot be seen. Was this on a condo or townhouse with common party walls? also when was it built? Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry
The home was built in 1946. It is a single family ranch home. My accross the street neighbor has the same sheathing as I remember last year when it took him days to tear off a small area of the sheathing as it breaks into little pieces and doesnt remove like plywood or flakeboard. Thanks for the replyies mates Dave |
Hi Dave,
I very much doubt that that is in fact FRT, FRT would normally only be used on property such as condos and town houses where fire protection is required for the roof decking 4 feet either side of a party wall, also FRT was not used before the late 1970's. I believe that what you were looking at was just older moisture damaged plywood which had darkened due to age, damp, and airborne contaminents. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I'm with Gerry. I used to see FRT all of the time, and have never seen it on a single family home. It is more expensive, and even if the 40's roof was re sheathed in the 70's it is very doubtful the roofing contractor would have spent more money for a sheathing that was not required.
Moisture damage and age is your culprit here. |
Gerry and Blaine ... I second that notion ...
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| What Happened Here Tile Roof Plywood Decking | pmagrone | Exterior Inspections | 21 | 7/19/07 1:08 PM |
| Attic Plywood | gporter | Interior Inspections | 13 | 5/30/07 1:31 AM |
| Plywood mixing box? | djones6 | Inspecting HVAC Systems | 1 | 4/5/07 12:22 AM |
| Treated Plywood ? | Homey | Structural Inspections | 4 | 3/23/07 2:10 AM |
| 3/8" plywood roof sheathing | kshepard | Exterior Inspections | 12 | 8/15/06 7:28 PM |
