Greg Gold is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just a quick question, hopefully someone can help me out. Gable end 36" and under, does it require bracing per 2001 code. I'm a poor homeowner facing rate hike x4, already removed eves to add 1 nail in roof to wall straps to bring to the min. of 3 nails. Any tips will help, greatly appreciated to all. Thanks
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Calling all Florida wind mitter's.
Guess no one wants to touch this one ?
Greg,
That is a tough one to answer. As of 2001 in Florida, truss designers were required to design by the specifications published jointly by BCSI and TPI, which do not require bracing for gables that are 3 feet in height or less, but the odd man out here is that the code also specified that all truss bracing design be the responsibility of the Designer of Record. So even though prescriptive methods may not require bracing the designer may have added them to the construction documents. The supplements to the 2007 Florida building code have methods for retrofitting if you would like to harden off the gables. While OIR-B1-1802 has a check off box for gable bracing the insurance companies do not provide a discount for the bracing. The new form that comes into affect February 1st 2012 has removed the gable bracing question Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
Where are you located?
What type of shingles are on the roof? How many gables do you have. Please call me at 561-537-6997...maybe I can help you.
| Gable End Wall Bracing Can Be Complicated | pcampbell | Florida Inspectors | 12 | 12/30/11 7:32 PM |
| Gable ends for wind mit inspections | kmoore3 | Structural Inspections | 2 | 9/27/11 3:43 PM |
| Gable end bracing | jshishilla | Florida Inspectors | 5 | 7/28/11 8:45 AM |
| Hip or Gable | sjohnson | Florida Inspectors | 11 | 7/4/11 10:54 PM |
| Gable end bracing | jshishilla | Florida Inspectors | 7 | 3/13/11 3:03 PM |
