Is there any code for the number and size of passive garage air vents "suicide vents"
Russell...those garage vents are a local thing...check with your AHJ..they are not used at all just up the road from you where I'm at. From briefly looking at your town's building ordnance they do not appear to be required and I don't know of any IRC requirement for them.
BTW, some folks might not know what you are referring to...do you have a photo of one? I might but it will take awhile to find it. Last edited by mboyett; 2/8/07 at 7:48 PM.. |
Two documents that address natural or passive ventilation in garage door space are the International Mechanical Code (IMC) and ASHRAE 62 which is also referenced in the IMC.
The general requirement is 100 cubic feet per minute per vehicle allocation within a garage space; however, a comment based in ASHRAE 62 reads that garage space air ventilation requirements are “normally satisfied by infiltration or natural ventilation.” In actuality, the garage door opening itself can be considered a “natural vent” not only because of its obvious capability of opening and closing but also because its area is usually more than 4% of the area of the affected garage space. Therefore, vents in garage doors should not be needed for natural or passive ventilation. |
Thanks for the replys. I was thinking that there was a requirment for the garage to have the vents installed and to be a certain size per the footage of the garage. I will go from here. Thanks for the help.
Thanks Micheal
JMO & 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Robert Michael Weller is a non-member guest and is in no way affiliated with InterNACHI or its members.
In Ventura County (California) are these passive vents required, and if so how is the size and quantity computed?
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 12:08 AM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 12:07 PM |
| Giant hole in the garage firewall for HVAC VENTS | mpeterson | Structural Inspections | 14 | 2/3/07 5:54 AM |
