Old 8/28/10, 12:10 PM
Jeffrey R. Jonas's Avatar
Default Garage concrete slab question
(Pic 1) 1981 two story w/full basement, with attached 3 bay garage...
(Pic 2) Gap in concrete between garage slab and driveway. Driveway has minor slope to street. Driveway has some cracking, but no heaving. I see this often, and is generally an easy fix.
(Pic 3) Garage slab at rear wall has excessive gap. Runs the entire length of rear wall. Gap measured 1-1/4 to 1-1/2 inches.
(Pic 4) Garage slab at front (vehicle door) wall. Notice no gap at wall, but see gap from pic 2 on other side of wall.
I have seen small gaps develop from concrete shrinkage, usually 1/8 to 1/4 inch. The slab has the typical hairline shrinkage cracking, hardly noticable. I have never seen this severe of a gap before. It is only at the rear wall. There is no evidence of the wall bowing, leaning, shifting, etc... There is no damage to the block foundation wall (visible) other than the mortar has hairline cracking in some areas. No noticeable displacement of the blocks.
Question: Does anyone have any idea what may have caused this gap? I swear, looking at it you would think it was done on purpose. As there appears to not be any issue with the walls, do you feel it to be of concern?
Note: Already informed client, in person and in report, to get an SE, as there are other framing issues in the home to be evaluated.
Thanks in advance,
Jeff
Bonus: for you "eagle eye's" inspectors... can you spot at least two other issues in Pic 4 ???
garage-concrete-slab-question-leonard201008271r-002.jpg   garage-concrete-slab-question-leonard201008271r-008.jpg   garage-concrete-slab-question-leonard201008271r-192.jpg   garage-concrete-slab-question-leonard201008271r-186.jpg
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/28/10, 1:09 PM
ldapkus ldapkus is offline
Default Re: Garage concrete slab question
It's probably a degraded/removed expansion joint I have some at my home where a concrete patio was poured next to existing stairs. The black expansion joint degrades and leaves a gap.
Old 8/28/10, 1:47 PM
Done on purpose, even at an 8" slump concrete would not shrink that much.
Only 1 anchor bolt on the sill plate.
Doesn't appear to be PT
Where are the Auto reverse eyes for the garage door?
Old 8/28/10, 4:08 PM
Thanks for the reply Linas. I considered that also, but the expansion joint in all other areas is in excellant condition. Also have never seen a 1-1/2" joint in a garage before.
Old 8/28/10, 4:24 PM
Marcel,
Thanks for your expert opinion. I was hoping you would see this thread. I know you have years of experience with concrete, and I trust your opinion completely. (No offense to anyone else).
Very good on the anchor bolt, but look at the bolt closer...
Correct on the PT (no sill plate seal either)...
Auto reverse eyes... how can you tell it has an opener? Actually, two of the three doors have openers, and the sensors are mounted on a 2x4 at the ceiling!
No opener on door #3 due to what you see in pic's # 3 & 4.
(Bet you can find a lot more defects in this batch of pics)!!!
garage-concrete-slab-question-leonard201008271r-194.jpg   garage-concrete-slab-question-leonard201008271r-195.jpg   garage-concrete-slab-question-leonard201008271r-190.jpg   garage-concrete-slab-question-leonard201008271r-189.jpg
Old 8/28/10, 6:07 PM
Originally Posted by jjonas View Post
Marcel,
Just not loggical Jeff. Something had to be there to create that gap and hold the concrete away from the wall while being poured.
Could be something stupid like an 1-1/2" styrofoam applied to the foundation and was never cut off at the right height before the pour and taken out later. Typically, a 1/2" foam seal or impregnated asphalt board, such as Vapor Seal would have been used for an expansion joint inside and also at the driveway side.
Since this looks like a concrete driveway, it is possible to get a shrinkage crack of that magnitude.
See a Silhuet of a bolt, that was it.
I did pick up on the sill seal, but figured I was not writing a report.
Anyone that can afford a three door garage will have openers.
Hard not being there and looking at a photo only.
Wiring mess.
No fire seal tape at drywall
Loose wiring
Missing outlet plate
Overhead door brackets should have been perforated angles to eliminate combusitble material and breaching at ceiling.
The house is possible to have had a fire separation all the way up to the underside of the roof.
Can't make out wall construction at the separation house/garage.
Elec. for winch and lights appear wrong
Dangling vapor barrier
Fire Extinguisher? was it charged? ha. ha.
Where is the engine?
Where are all the work outlets, I don't see any.?
How my doing. ?
Old 8/28/10, 6:53 PM
How my doing. ?
You did awesome. Never really expected for you to even try.
What you are failing to see concerning the anchor bolt is the obvious! You see the bolt just fine... but what you are missing is it doesn't have a nut and washer, so even if it had a second anchor bolt, without a nut and washer it is useless !
BTW... I think I found as many or more defects/concerns in the garage as I did in the rest of the home. I will post more in a few days for your enjoyment. You'll love the one about the "missing beam".
Thanks again for your advice and for playing along.
Old 8/28/10, 7:11 PM
What you are failing to see concerning the anchor bolt is the obvious! You see the bolt just fine... but what you are missing is it doesn't have a nut and washer, so even if it had a second anchor bolt, without a nut and washer it is useless ! Could not see the darn thing at 200%. Plus, unless you have a Category 3, where is it going to go?
It just dosen't meet the standard of building in the industry. Oh! and the IRC.
BTW... I think I found as many or more defects/concerns in the garage as I did in the rest of the home. I will post more in a few days for your enjoyment. You'll love the one about the "missing beam". How was it hooked up in the attic.
Hey, it's all in fun.
We need to start something like that on Dom's site too and maybe we could call it, "Guess the Defect"
Old 8/28/10, 7:51 PM
Yes, it is. All in fun, and educational to boot.
Sounds like a great idea. I'll start one on both MB's on Monday starting with the beam issue.
Old 8/31/10, 4:18 PM
Joseph W. Keresztury's Avatar
Joseph W. Keresztury Joseph W. Keresztury is offline
Good idea Jeff and Marcel. Those kinda posts are enjoyable and educational. Looking forward to it.
Joe Keresztury
JWK Inspections
Home Inspections in San Antonio,
Schertz, Cibolo, New Braunfels, Boerne
and all surrounding South Texas areas
www.jwkhomeinspections.com
Garage door opener Question dnasser Exterior Inspections 2 11/10/09 9:45 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Room Under Garage Question? rfrost Structural Inspections 7 7/10/07 3:00 PM
Garage fire protection question bwooddell Structural Inspections 10 6/23/07 7:52 PM
