Old 1/21/12, 7:13 PM
Kenny Rigler Kenny Rigler is offline
Default Garage Support Beam
Hey Guys-
This beam was in the garage of a split-level (kind of) style home with a living space above it. The beam was (3) 2x8s and the span was 22'. However, on the inside wall, the beam sat directly above the door to the house and there wasn't any other structural support for about another 10' into the house where the next wall sits. Directly inside the garage door to the right is the stairs to go to the upper level. Do you think they ran that all they way to that next wall? What's supporting the beam? Thanks.
Kenny
garage-support-beam-gedc8548.jpg   garage-support-beam-gedc8576l.jpg   garage-support-beam-gedc8577.jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/12, 7:30 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Default Re: Garage Support Beam
Kenny
With out knowing the loads involved its difficult to help. Main beams made from 2x12 carrying typical floor loads usually span about 12 feet. Is it possible someone removed a support post from the center of the garage? That piece of sheet metal on the bottom of the beam, would that happen to be in the middle of the garage?
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 1/21/12, 8:28 PM
Originally Posted by rmayo View Post
Kenny
I didn't consider that, but yes it was about in the middle.
Hays, KS 67601
785-656-0272
Old 1/21/12, 9:32 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Randy there should also be a full support at the end of this 22 ft beam, so this is double wrong. According to a proper practice the (3) 2x8s need to be supported by (3) 2x8s It can be off by what is pictured but the wall would need to be more than 7 inches or have a steel column and the header would need the same, it is not likely this was done.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/21/12, 11:30 PM
Kevin
The column support does not have to be 2x8s. Three 2x4 if properly supported can hold a significant amount of weight as a column. If you look closely at your first picture just behind the sheet metal on that beam I can see where some type of support column may have been. I would just call it out as a potential structural issue. The burden of proof then falls on the home owner to prove otherwise.
Randy Mayo, P.E.
573-201-8162
Old 1/21/12, 11:47 PM
Joseph Hagarty,  CMI's Avatar
In addition to the modified Beam
- You have HVAC ducting passing unprotected (which indicates Living Space above). This indicates improper fire separation between home and garage.
- Insulation improperly installed
- Receptacles missing covers
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/22/12, 8:45 AM
KEVIN WOOD's Avatar
Yes Randy that is a good point and is possible. When I have seen this type of situation it is sometimes under supported by (2) 2x4s in the wall and I would still put a note if there where (3).
The post removed was probably a 8x8 wood post.
Joseph that is correct and the third picture confirms the breach.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/23/12, 2:16 PM
Thanks guys. There were several issues with the electrical and firewall separation. The main beam setting above the doorway just really surprised me.
Hays, KS 67601
785-656-0272
attached garage ghelder General Inspection Discussion 5 2/23/10 5:40 PM
Garage floor same level as house a safety concern? thorn2 General Inspection Discussion 11 1/25/10 3:33 PM
Garage door inspection procedure bgromicko General Inspection Discussion 5 8/7/09 12:47 PM
Inadequate garage support post? jfunderburk Structural Inspections 29 8/7/09 1:17 AM
Steel beam lateral support Mark Ellison Structural Inspections 10 1/16/07 10:40 PM
