Are vents required in garages? Especially if there is a gas fired water heater or furnace? Lately I've been inspecting some newer construction (2003 or newer) and there are no vents installed.
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
In rare cases a vent will be required. It all depends on the manuf requirements that are based on type of equipment, total btu's and size of the garage. Some water heaters that vent out a side wall have a section of the same duct that also provides intake air.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
The garage itself does not necessarily require venting. I'd have to look up the reference, but I believe the CMC states that venting is not required when the garage is less than 1000 sq ft and is used for "storage" of 5 or less vehicles.
"Additional" venting is required when the size of the garage (cu ft) will not adequately support combustion for all of the gas-fired appliances located within. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Garage fire wall question | jscaparo | Interior Inspections | 10 | 10/3/10 1:05 AM |
| Garage floor same level as house a safety concern? | thorn2 | General Inspection Discussion | 11 | 1/25/10 3:33 PM |
| What do you inspect ? (Garage) | belliott | Exterior Inspections | 22 | 10/15/09 5:39 PM |
| Garage door inspection procedure | bgromicko | General Inspection Discussion | 5 | 8/7/09 12:47 PM |
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 12:08 AM |
