Old 2/3/12, 8:11 PM
John M. Zirzow's Avatar
John M. Zirzow John M. Zirzow is offline
Default Girder Pics... Why
This house is about 1000 Sq ft, The girder was made out of 2X4 and many of them as you can see and between them they used OSB as If they were buiding a header. The 4x4 post are not supported properly, No bolts everything was nailed or screwed. Just want to be sure with all of you and share some good pics, Your thoughts please THANKS !!
girder-pics-why-img_7137.jpg   girder-pics-why-img_7136.jpg   girder-pics-why-img_7139.jpg
John Zirzow
Homestead Inspections llc
Eagle River, WI 54521
715-479-4151
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/3/12, 8:23 PM
Default Re: Girder Pics... Why
Wow, one would think the deeper masonry pocket would have been a hint.
Larry Kage, CMI
231 929 3525
Old 2/3/12, 8:28 PM
Tim Spargo's Avatar
I guess the store was fresh outta I Beam or ....
Silly question, was there deflection on the floor above?
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 2/3/12, 8:29 PM
Christopher Currins's Avatar
Guess they wanted to save on materials, add a block, used form boards for beam, and extra 4x4 laying around. A lot of effort to do it wrong.
Christopher Currins
Certified, Licensed
Old 2/3/12, 8:31 PM
It appeared to be solid home was built in 1980
John Zirzow
715-479-4151
Old 2/3/12, 8:36 PM
You are so right Larry to go though all that work to build up that pocket
John Zirzow
715-479-4151
Old 2/3/12, 9:13 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
This was common in the early 1900's. Every home I inspected had 6 2x4's spliced together to make the main beam. Every house with this design sagged in the middle. I think they did it for head room because every basement was too short to stand in.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 2/3/12, 11:17 PM
Kenneth R. Brittain Kenneth R. Brittain is offline
This gets my vote or I don't like that big beam in the basement we may want to finish it some day.
Old 2/4/12, 11:05 AM
I see solid 8x8's or larger in that vintage home. Like this one with the octopus:
Larry Kage, CMI
231 929 3525
Old 2/4/12, 11:07 AM
James F. McKee's Avatar
great picture Larry...I haven't seen one of those in a while....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 2/5/12, 11:11 AM
KEVIN WOOD's Avatar
You would not find a beam like that in some of our old homes and I have never seen the Octopus either in my time of inspection. Our basements are so short that you could not install one anyways.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
girder question ryoung7 Structural Inspections 10 1/17/12 5:00 PM
Is this a Defect? Some various pics attached tspargo Interior Inspections 19 6/18/11 8:40 PM
Proper girder bearing? jfunderburk Structural Inspections 8 9/11/08 1:00 PM
defect pics wanted mnelson1 Miscellaneous Discussion for Inspectors 5 3/9/07 11:05 AM
Need HVAC Pics! hgordon Inspecting HVAC Systems 2 2/17/06 10:06 AM
