Old 9/5/06, 10:56 AM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Default Hangers?
Fellow HI's.
Here is question I can not find an answer for. Did an inspection yesterday at a house (I guess you could call it that) that has manufactured wood I beams installed. The question is.....is there a certain type of hanger used for wood I beams or is a hanger just a hanger? Any help would be greatly appreciated.
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 9/5/06, 10:57 AM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Default Re: Hangers?
Beams!!! or joists???
Beams are usually supported from below.
Joists go on hangers.
Old 9/5/06, 1:01 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
i'd check manufacturer's directions.
lots of different hangers out there.
some can be used for engineered or non engineered applications.
some can only be used for one or the other.
any pics?
try these sites
http://www.strongtie.com/products/Ca...?source=topnav
or
http://www.tamlyn.com/index_files/To...WoodIJoist.htm
Old 9/5/06, 3:40 PM
William J. Decker's Avatar
1) Usually, regular joist hangers can be used. Always check with the manufacturer, but LP OSB I joists are OK with it.
2) Make sure that the just didn't toenail the suckers.
3) Check spacing between joists. Usually 16" OC, but can also be 24" OC. Again check with manufacturer.
4) They usually allow 2-3", once in a while, to handle a partition wall above or some such.
5) All the infor is usually printed right on the joist.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 9/5/06, 4:32 PM
ok- somebody give me a quick class on how to install a picture...I have had a brain cramp from looking at the IBC book today.
NACHI05062580
Auburn, Alabama
WAR EAGLE!
Old 9/5/06, 4:44 PM
Michael Larson's Avatar
See following tutorial:
http://www.nachi.org/tutorials/tutor...mb-attachments
Old 9/5/06, 5:16 PM
Hi. John;
In most cases with joist hangers, it depends on what kind of joist we are talking about. In cases of regular stick building, with conventional joist or rafters, regular lumber yard hangers will suffice.
In cases with structural Engineered Lumber framing, it is most appropriately designed with the system from an Engineer or Architect, where it will be specified for it's use. If not, then maybe contacting the Manufacturer of the product, and usually their recommendation to specific hangers will be listed with the design of the floor system or roof system.
Most of the hangers manufactured are of a long line of designers and can only be qualified and selected by Engineers of the Manufacturer or a Structural Designer if involved.
I added this link for your review of the many possibilities of uses.
Hope this helps.
Marcel
Old 9/5/06, 5:37 PM
Typically, conventional joists use a face mount flange hanger and I-joists use a top mount flange hanger:
ID:	5434   hangers-itt-top_flange_cwp-small-.gif.gif
Old 9/5/06, 7:18 PM
These are just three example; therefore, there needs to be some engineering involved. I would think.
Marcel
Old 9/5/06, 7:19 PM
Peter C. Russell's Avatar
Just a fact to point out, When inspecting newer houses with MFG. I joists for floors, when installed they need to be installed slightly lower than the beam to allow for expansion and contraction, so if you see flooring in a newer home buckling check the I joists in the basement. Many times a builder will install them flush to the main carrying beam and they tend to expand pushing the sub floor up.
Old 9/5/06, 7:25 PM
rwand1 rwand1 is offline
Watch out for nailing. Find many that have not been fully nailed.
Old 9/5/06, 7:25 PM
Actually what I meant to say is the main beam that the I joists are attached to tend to shrink thus making the joist push the sub floor up. Here in NE we buy kiln dry lumber which I believe is dried for about 30 minutes and then out in the yard up for sale, always green and worse in the winter because it freezes in the yard and doesnt dry until the heat goes on.
Old 9/5/06, 8:09 PM
Peter, you can correct me if I am wrong, but the last Project I did with TJI's or I joist, it was reccommended that the underlayment span the girder beams by 1/4". Not backing it up with a link is my downfall I guess. Sometimes they are not readily accessible. The theory or fact behind that is, since the carrying beam of the floor structure is more of a massive volume, it tends to shrink less than the members attached to it. So, therefore, shrinkage if existing in the floor members perpendicular to the main supporting beam exist, the 1/4" will compensate without creating a bump in the flooring material.
JMHO.
Marcel
Marcel
</IMG></IMG>
Old 9/6/06, 8:30 PM
Marcel, not sure if we are on the same page, I was referring to the joist not the sub floor or underlayment. I was referring to an I joist that is connected to a stick framed carrying beam that is usually made out of 2x10s the I joist will not shrink but the main carrying beam will thus pushing against the sub floor. Your thoughts?
Old 9/7/06, 10:25 AM
Peter, with top flange hangers beam shrinkage won't matter, the Joists will still be in the same position relative to the top of the beam. I've never seen I-joists installed on a beam in which the tops of the beam and joists were supposed to be flush without using top flange hangers although I'm sure someone somewhere has decided to use up those hangers that've been stashed away in his garage and save $25.
All in all, we don't have to confirm compliance to engineering. I called one roof system in which the framers had nailed truss-bearing hangers with siding nails (40% smaller diameter and a different alloy) but unless it looks bad or you know it's wrong, why call it?
Joist layout would be called out by an engineer and it might be 12", 16", 19" or 24" on center (center to center, not in between). Unless the floor or roof exhibits exfcessive deflection, joist spacing is not our problem. If it does, then call out excessive deflection. -Kent
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Joist Hangers at Cantilevered Rim pdickerson Exterior Inspections 21 8/18/07 6:19 PM
Pipe hangers Ian Gills Plumbing Inspections 4 5/11/07 5:17 PM
3-2 mono roof truss anchor dthomas2 Structural Inspections 8 10/2/06 11:36 PM
