I'm looking for any info I can find on a structural block I have never seen in use before....this is a pre-1900 house and these blocks are in use for the entire foundation below grade....that being said, foundation has typical moisture issues, etc. Looking at these blocks, I can't believe they hold up the house......they appear to be made of concrete.
Thanks! |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat |
Looks like Tile Blocks to me Not very strong damage easy and when I saw them used it was in Apartment building as divider walls around 1960 .
Never seen them since Roycooke@hotmail.com I prefer E-mail "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk |
Thank you both, gives me more to go on.....
I am truly amazed at times when I see the methods of construction used in areas where the earth stands still. This type of construction would have "taken care of itself" long ago if it were in CA...
I'm interested to know how you "justify" recommendations for any corrective or proactive action when you come across this stuff when it has been standing for more than a hundred years, and there are no indications that it may be failing. What (if anything) can you expect to happen over the next hundred years that might change the integrity of this structure? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I sruggle with that as well, Jeff. In my area, we have a lot of older homes on fieldstone foundations that look terrible but yet, are 100-150 years old!My usual take on it is to point out the big picture (age and O/A condition) and then recommend a secondary inspection by an "expert" if they are not comfortable with my findings. 99% of the time, people understand that a house this old is non-conforming with todays standards and take their chances.....In our area, SE's tend to overreact and overkill their recommendations...
PS....if there were earthquakes happening in Michigan like you guys see in Cali, half of the houses in this state would fall over.......
Not a big conflict
House was built by whatever standards or practices were available at the time it was built. Simply because it is outdated and non-desirable today does not mean it needs to be corrected. It is never our job to predict the future, only what we see at the time of inspection. Foundation is straight, undamaged, supporting the house, then no problem. Report any defect of the current structure. Is it broken, damaged, falling over that may need to be repaired If not then I would verbally mention to the client that it is a weaker type of foundation that may need excessive maint, or repair in the future. I remind them that so far the foundation has stood well for a house that was built in 18XX. Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Council Bluffs Home Inspector Iowa Home Inspector Council Bluffs - Facebook Active Rain Member |
We have houses here near the ocean built around 1900 with that 6" clay block from the footing to the roof with stucco surface. Still there with all the hurricanes.
Preston L. Halstead VP FL Home & Insurance Inspectors Chapter Elite Property Inspection & Management LICENSED GENERAL CONTRACTOR CGC1515203 LICENSED BUILDING INSPECTOR BN6262 LICENSED HOME INSPECTOR HI549 HOME INSPECTION ~ WIND MITIGATION INSPECTION Serving Boca Raton, Boynton Beach, Delray Beach, Juno Beach, Jupiter, Lake Park, Lake Worth, Lantana, North Palm Beach, Palm Beach, Palm Beach Gardens, Royal Palm Beach, Wellington, West Palm Beach.
Very common in apartment buildings built around 1900 or so.
Very strong but will crack easy if drilled. No issues. Go here to learn more https://www.google.com/search?hl=en&...CsXGygHRrIHwBA (clay tile) |
Terra Cotta as Mikes Link shows.
I repaired a house back in 1973 where the basement walls were all constructed with it and plastered over. Sorry, no photo. LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
Here is a link to a good This Old House article from a report I did in January of 2008.http://www.oldhouseweb.com/how-to-ad...ra-cotta.shtml Below are a few of the pictures and comments from my report on this condo conversion of the old Goldblatts dept store (downtown Chicago) The majority of the wall surfaces are the terra cotta with the drywall primarily in the laundry bathroom areas. Observations: Material failure in glazed architectural terracotta is necessarily complex. For this reason, it is generally advised that the examination and repair of this material should be the responsibility of an experienced professional. Few restorationists have experience in the inspection, repair and replacement of glazed architectural terracotta. This is certainly never the province of the amateur or the most well intentioned but inexperienced architect or engineer. There are some methods of internal and external inspection and analysis which are relatively simple to the trained professional. Other methods, however, are expensive, time consuming, and only in the experimental stage at this writing. These all generally preclude the use of anyone but an experienced professional. Windows appear to be missing frame screws but it may have been found to cause damage to the terra cotta when installing.I would find out if all these windows in the building were installed in the same manner Window frames were warped from using wedges to force fit in place. [ATTACH] [/ATTACH]
Key word this ...."Structural Terra Cotta"...."Structural Clay Tile".
Yes Bob, good article.
The grooves, or ribbing, on all four sides help mortar, plaster and stucco adhere to the surface. Above grade, plaster is applied directly to the interior side of the structural terra cotta blocks. The exterior is often coated with stucco. LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
Pretty sure you can look up me asking about it right here on the forum somewhere under 1/6/2008. Marcel you are most likely one of the guys who answered at that time. Guess I just take too many pictures...useless.lol |
