Old 9/19/07, 9:12 PM
hziegenbein hziegenbein is offline
Please Note: hziegenbein is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Heavy timber posts and support beam
Did an inspection on an approximately 80 year old wood frame construction victorian. The support colums in the basement wer old heavy timber approximately 6"*6". All of the columns wer straight but there were some long cracks running with the grain, the same type of cracks were running along the heavy support beams. They also had shimmed the support beams above the posts and the floors above were noticebly raised where they were shimmed. The basement was finished so I couldn't see the floor joists. It appeared as if everything had been this way for a while, there was no cracking or anything in the plaster in the house, but there were a number of uneven ceilings. I've seen this in several similar style houses. Two questions: am I correct that the cracks in the beams/posts are just from the wood aging and acceptable since they run with the grain? And even there are no other signs would you recommend this to a structural engineer, has anybody run into similar situations and were there any reasons for what was done?
Thanks in advance
Hans
Home Savers Home Inspection Services llc
heavy-timber-posts-and-support-beam-post.jpg   heavy-timber-posts-and-support-beam-beam.jpg
Old 9/19/07, 10:39 PM
Default Re: Heavy timber posts and support beam
Thanks in advance
Hans
Those "cracks" look like checking which occurs when solid wood beams dry out naturally. As the beams dry out they shrink and the checking accomodates that but has little effect on the strength of the beam and does not need to be repaired.
Of more concern would be cracks all the way through the beam, notches especially along the bottom, excessive sagging of the beam, rot (check at the bottom of posts), etc.
Larry Kage, CMI
231 929 3525
Old 9/19/07, 11:34 PM
What Larry said. Checks no problem.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 9/24/07, 4:38 PM
Thanks for the input.
Old 9/24/07, 9:22 PM
rwand1 rwand1 is offline
These are typical "checking" cracks not of concern.
Wood Industry Fact Sheet - Checking
http://www.wvu.edu/~Agexten/forestry/wooddr2.pdf
Floor support posts kgerhauser Structural Inspections 7 7/17/07 1:23 AM
Steel post question sspradling Structural Inspections 42 3/2/07 9:59 PM
Support posts in crawl space lfoster Structural Inspections 14 12/11/06 7:28 PM
Support post for Beam, is this right? mlong Structural Inspections 63 7/25/06 7:34 PM
