Some may remember my past post(s) concerning my own foundation settlement issue. I've finally got off my rear end and got estimates from 3 foundation companies. I have it narrowed down to two. One recommends six helical piers while the other recommends 7 steel push piers. What are your opinions of the two? Give me the good, bad and ugly
Robert,
Can you provide links to their WEB sites so that we can view their pier offerings? As for steel push piers I would not recommend them to anyone. Steel likes to rust and even if coated you can expect the coating to wear during installation. Push piers are not very good for active soils as there is always the potential of them being pushed/squeezed upward. This has been a problem with expansive soils and push piers. Yes most helical piers are steel but at least they offer some of the characteristics of belled and poured concrete piers. Here is one interesting site for helical piers: http://www.helicalpierworld.com/ Whatever you do, if you use any steel in piers also make sure they are using primary steel of the proper gauge. There are some foundation repair companies out there who are using cheap secondary steel in their piers. These tend to fail and corrode quickly. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
www.trottercompany.com and www.anglinsfoundationrepairs.com Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
The helical company seemed more professional for what it's worth. If I use them I'll have to hire a seperate brick mason to do the cosmetic repairs. The steel pier company provides the brick repair along with the piers. Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
Lifetime warranty, sounds good. Check references and good luck.
Lifetime warranties are only as good as the longevity of the companies that issue them, Read them carefully, or better yet, have them read by someone who won't just read what he or she wants to read, and preferably someone who is very familiar with construction, so they can tell you what could happen that won't be covered. To me, a lifetime warranty is an invitation to mistrust. Do the homework.
Robert,
The company I have successfully used with many clients insists on incorporating a lifetime transferable warranty on all pier work, initial and final, third party engineering reports and final plumbing tests. Pressure test on supply and static on the drain. In the event you have questions about the number of and placement of the piers consult the engineer they are using. S/he should be able to address all questions to your satisfaction. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Good points and well worth having done! There are some good companies out there. Which company is this you speak of? Do the engineering reports contain before and after elevation readings as well? Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
An update... I'm back on Terra Firma!!! I finally decided to go with a company that installed push piers (total of 7), made the needed brick/mortar repairs, and provided a lifetime transferrable warranty. They started at 10Am and completed the job at 9PM. No more sticking doors, cracks, etc. The crew was great and encouraged me to watch and learn. I was with them the entire day and learned a lot. I don't wish this experience on anyone.....but it was an education which will help me with future inspections...hmmm, wonder if I can get a few CE credits for that
If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
I'm not sure if this will work but let's see..... http://www.kodakgallery.com/ShareLan...fromshare&Ux=0
| What's the point of these piers? | jfunderburk | Structural Inspections | 25 | 3/25/06 8:39 AM |
