jsmith3 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Can anyone help identify this type of foundation? It looks like clay tile with the reinforcement ribs laid horizontally. The house is over 100 years old and this is under the original part.
Thank you, Jon |
Jon,
You guessed right. These were quick common in the late 40's and into early 60's. Clay tile were used before concrete block were available in some areas. I carried many of these for my dad who was a brick and tile mason. I have seen these in areas were there was a brick plant. Lynn W. Gerving |
However, keep in mind that the way they are laid is NOT ideal. The hollow cores should run vertical not horizontal. The blocks can crush easier when installed in this way.
| Termite treatment for concrete block foundation | jbraun | General Inspection Discussion | 14 | 8/2/11 1:36 AM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Concrete block foundation | rwand1 | Structural Inspections | 1 | 10/3/07 11:28 AM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
