Looks like the ridge beam is too short and the hip rafters do not properly attach. Inadequate support below hip rafters also.
Your thoughts? John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
Looks pretty weak.
How was the vertical support on the hip rafter? I always make sure that it is supported every 12 ft. measured (estimated)horizontal. IT would be easier to add extra vertical support to correct that issue than tear it all out. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Hi. John, and your right, call it out and reccomend a contractor to repair.
The connection should have looked like this and no ridge support required. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Improper cuts, wrong angles cut on the ends of the hip rafters. Very easy to cut wrong; when the carpenter can’t calculate length, angles or use a framing square properly to layout hip rafters.
Gary |
Look at your pics closely. They may have also spliced the roof rafters without proper support.
Seen that too ! |
Typical Texican framing...they mis-cut and add scab material to try and compensate or mask their F-up.
Gets called out in 8.725 The roof system framing does not comply to the known industry standards. I advise consulting a structural engineer to design methods of the required appropriate repairs. The ball is then in their court and on the engineer, or not in most cases until something happens and then I get the call and remind them to re-read their report. This is after repairs were made, oops! Client got tired of paying me after 3 re-inspects and bought as is. With a final report stating none of the repairs were proper. The seller filed a complaint on me for inappropriately harsh inspection reporting with TREC. They told him to go F-himself ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 12:56 AM.. |
How do you feel it's working for HI's? |
Other than it looks like it was all framed with 1x4 or some other 1x material instead of 2x , the main problem appears to be that it's nailed with finish nails instead of framing nails. Call it out as defective in a heartbeat, recommend a SE. This is bad work.
Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Besides not cutting the roof joist long enough, they also improperly cut some of the roof joist one way then cut it the other way and installed it.
| Attachment | nbhi | Structural Inspections | 2 | 7/27/07 1:19 PM |
| Ridge Board....What's That? | pabernathy | Structural Inspections | 35 | 2/22/07 11:25 PM |
| Acceptable roof rafter repairs | ldapkus | Exterior Inspections | 14 | 7/17/06 11:49 AM |
| Overnotched Rafter | hspinnler | Structural Inspections | 23 | 1/8/06 5:55 PM |
