What is the maximum size hole that can be put into the web of an engineered wooden truss floor joist?
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
Truss members and components shall not be cut, notched, or otherwise altered in anyway with out the approval of a registered design profesional.
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
Found it on a past post....mark I think you were thinking of Roof Trusses
http://www.ilevel.com/literature/TJ-4000.pdf |
![]() Drilling holes in I-joists. The flanges must never be cut or notched, but fairly large holes can be cut through the webs (the largest holes are permitted at midspan). TruLine Truss staff should be consulted to determine maximum diameters for holes near supports.
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Exactly...see the manufacturer's installation info...
Thanks Guys
| Can someone explain why wood in contact with concrete causes rot? | gromicko | Miscellaneous Discussion for Inspectors | 46 | 1/17/11 12:15 AM |
| cut floor joice | John E. Gibson, #2 | General Inspection Discussion | 16 | 9/25/08 10:45 PM |
| The Rise and Fall of CCA Wood Preservatives | mcyr | General Inspection Discussion | 3 | 5/4/08 12:19 PM |
